Page 8 of 8 1 2 3 4 5 6 7 8
Re: Finally road test results! Magnum heads! [Re: eightlitermopar] #1180444
05/20/13 11:24 AM
05/20/13 11:24 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
The old cam was your stocker 318 2bbl cam, and there were some bent pushrods. Some of the rods measured .020-.040 shorter with the bend calculated
EDIT:The new one is the comp extreme engergy 250H cam.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=624&sb=0
Consider the specs with a 1.6 ratio and I have alot more lift. More of a torque cam than a street terror powerhouse. I chose this route for the road-tripping torque rather than racing.
eightlitermopar
you should feel things much stronger above 3500-4k....
my old '86 M body's 318 was all done by 4000 RPM stock. it's advertised torque peak was 2000 RPM....granted I never had headers and a 4bbl on that engine in that config....
that same short block with the magnum heads and my reground roller cam (used Bullet Cam's HR259/316 lobe) felt as strong as the 360 with an XE262 in it that I had in the car before I put the roller 'teen in.
the 259/316's specs are 259adv, 208@.050, 127@.200, .316 lobe lift (.506" with 1.6's)
your XE250's specs are 250 adv, 206@.050, 117@.200, .280LL (.461" with 1.6's)
with 10 degrees less duration at .2" lobe lift, and .045" less gross lift, I would expect your engine not to be as strong as mine was, but I would think it would feel much stronger above where the original cam/heads would nose over, which if the older 318 was anything like my '86, would've been about 3500 RPM...
how much ignition advance are you running? on my mag headed 318, it felt like it made the best power on the butt dyno with about 30 degrees total advance, and felt like it slowed down if you gave it older LA advance levels (36-40)....
2017 Grand Cherokee Overland
Re: Finally road test results! Magnum heads! [Re: patrick] #1180445
05/21/13 09:37 AM
05/21/13 09:37 AM
North Central Florida
E
eightlitermopar Offline OP
E
Thanks for the info Patrick!
I am hoping to get some more miles on it this week. I've been busy at work instead of driving it!
My to do list
1) Get a drop base air cleaner to fit the hood.
2)Put said hood on
3)Get some miles on it and see if it passes emissions
4) Fatten up the carb
5) Mess with the timing (I honestly have no idea at this point what my total is)
Thanks again! I will keep you posted.
eightlitermopar
Mopar or no car
Re: Finally road test results! Magnum heads! [Re: patrick] #1180446
05/21/13 10:43 AM
05/21/13 10:43 AM
Patrick was that with or without quench?
Re: Finally road test results! Magnum heads! [Re: RapidRobert] #1180447
05/21/13 10:58 AM
05/21/13 10:58 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
no quench...pistons were .055 in the hole and I used .028" gaskets....
Re: Finally road test results! Magnum heads! [Re: patrick] #1180448
05/21/13 11:09 AM
05/21/13 11:09 AM
Thanks Patrick. I have mag heads going on a non quench 318 so I will go with your recommendation of 30 total
