Re: Old 318 with new magnum heads...yay or nay?
[Re: BulletBob]
#1180324
02/18/12 02:20 PM
02/18/12 02:20 PM
Posts: 4,323 NY NY
340duster340
NY NY
why not just get a mag318 core and use that
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#1180326
02/18/12 05:23 PM
02/18/12 05:23 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
X2 may as well just change motors. They gotta be giving away 5.2 and even 5.9 Magnums by now. I'd even look into early 03-08 non VCT 5.7L Hemi's, even if just for reference sake.
[Re: 3hundred]
#1180328
02/19/12 12:33 AM
02/19/12 12:33 AM
Posts: 1,630 North Central Florida
eightlitermopar
I agree, the 318 mag is a sweet little package that blows the doors off the older ones. Mileage is good as well, wife's 318 magnum Ramcharger knocks down 20 MPG on the road.
318 mag is a virtual bolt in, very easy swap, old engine mounts are there, transmission pattern is the same, sealing is greatly improved over the old engine.
Robert
So the 904 would bolt right up?
I know the 518 would be sweet, but you can see where this is going. A simple regasket turns into...."well, while I am here, I might as well..."
I get carried away pretty quickly.
eightlitermopar
Mopar or no car
[Re: eightlitermopar]
#1180329
02/19/12 12:58 AM
02/19/12 12:58 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
904 will bolt up to a 5.2 Mag just fine (if you are converting the Mag to carb'd instead of OE injection). If you want to keep the Mag injected, You'll need to notch the 904 bell housing to allow fitment (of a crank position sensor???).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: BulletBob]
#1180333
02/19/12 10:33 PM
02/19/12 10:33 PM
GO_Fish
Maryland
Intake ports are about the same between LA and Magnum. Maybe you are thinking about the exhaust ports? There is a difference between LA and Magnum exhaust ports... bolt pattern is the same, but the floor of the Magnum port is raised for better flow. If trying to mate LA exhaust manifolds or headers to Magnum heads, I'd suggest using "Remflex" gaskets to make sure they seal at the bottom of the port.
Scott B.
[Re: BulletBob]
#1180335
02/20/12 08:03 AM
02/20/12 08:03 AM
eightlitermopar
So what about the cast iron heads? Did they have problems with castings for a while? It seems good, but I have to remember that a lot of these big full size vans or trucks with the magnum motor are in the junkyard for a reason. ![](/ubbthreads/images/graemlins/shruggy.gif) If so, what to look for, avoid, etc. ![](/ubbthreads/images/graemlins/wrench.gif) eightlitermopar
Mopar or no car
#1180336
02/20/12 09:22 AM
02/20/12 09:22 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
eightlitermopar
I've heard rumors they're all cracked, just not in a critical place. My wife's truck is about to turn over 298,000 miles with no engine trouble. I pulled the 360 out of the other truck with 168,000 miles for the hemi swap, not because it was having any troubles.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: CrAlt]
#1180338
02/26/12 03:06 PM
02/26/12 03:06 PM
Posts: 535 Marilla, New York
RalleyA12
Marilla, New York
Why not just keep it simple and swap on some '302 swirl port heads?
Everything you have now will bolt up. No fancy intake or manifolds needed. They are already set up for unleaded gas. And they flow better then the old 318 heads.
Magnum heads are better but if you are keeping the motor stockish i dont think they are worth all the extra crap you have to do to make them fit.
You must keep things in perspective, you're only feeding 318 cubic inches, you don't need a real high CFM head, leave those for the 408 stroker crowd. Pocket ported 302's with a 1.88 intake would be the way I'd go.
[Re: RalleyA12]
#1180340
02/26/12 07:43 PM
02/26/12 07:43 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
302's don't flow any better than open chambered 318 heads. they'll give you a better combustion chamber, hardened seats, and maybe 1/3-1/2 point compression boost, but heavily worked with 2.02's, they flow about the same on the intake (and worse on the exhaust) than factory magnums. not worth the trouble, IMHO
[Re: Dakota_Don]
#1180343
02/27/12 10:47 PM
02/27/12 10:47 PM
Posts: 394 Tennessee
classof65
Tennessee
I think Patrick needs to speak with Donnie Quinn about whether or not the 302 head flows the same as the other 318 stuff. Much of the "advantage" of the Magnum heads is due to the 1.6 rocker ratio. Let's look at this another way. Find a set of 315 castings (273) have a decent valve job and install them. The port velocity will more than make up for the volume increase of the magnum. Anyone out there got a 318 with magnums in a 74 - 76 A body? What's your ET and what kind of fuel do you have to run?
Just built a .030 over 318 with Sealed Power (el cheapo) pistons, I used the .411 - .399 stock eliminator cam out of our U/SA car, a set of 315 casting heads, a 273 HP cast iron intake, and a quick fuel 650 carb. ET 12.28 on regular pump gas. Granted it's got some gear, but that 75 Dart is HEAVY....
What I am saying is, there are several routes to the same destination, take the path with the least resistance. Oh, by the way, the valves are STOCK DIAMETER 273 jobs....
Peace, Rev. Mopar (Class of 65, 32 time National Record holder in U/SA)
