Seriously, "when are your front brakes big enough?"
#1179933
02/17/12 03:32 PM
02/17/12 03:32 PM
Posts: 22,812 Bitopia
jcc
Bitopia
Ok this is a Corners section and we ain't talking caliper color, 12 piston, $600K maybach's. ![](/ubbthreads/images/graemlins/eyes.gif) Anyway it it a question of merit. First, every solution has a downside. Too big of brakes wastes money, adds weight, adds unsprung weight, increases hp requirements for acceleration due to flywheel effect, and increases brake requirements because of flywheel effect, and slows steering response because of flywheel effect. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Seriously, "when are your front brakes big enough?"
[Re: jcc]
#1179935
02/17/12 05:22 PM
02/17/12 05:22 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It all depends on what you're doing and your driving ability.
Brakes convert kinetic energy to heat. The clamping force creates a HUGE amount of friction (obviously). That friction creates heat. A stock 10.75" brake rotor that is 1" wide can only dissipate so much heat. After it's too hot the braking ability will fall and it's time to stop. The large diameter rotors that are really thick will be able to handle more friction without overheating due to the extra mass. The same goes for the brake pads.
Monster brakes are useless on an autocross. You can't build up enough speed to really fry the brakes. Yeah, they'll be warm but you seldom drive for 2 minutes.
On a road course with a heavy car things will be different. The constant use over a long period of time will build a disturbing amount of heat.
Tires are important in braking but if driven improperly you can overheat just about any kind of brakes without burning up a typical street tire.
I managed to overheat the stock brakes on the hot rod while I was running BFGs. Since moving to the large brakes and performance tires I have not experienced any brake fade.
Is it possible to go too big on brakes? Certainly! The rotors I use on the hot rod weigh a staggering 37 lbs each. Put something like that on a light weight race car and it'll slow down measurably. It's simply too much mass.
Why did I use them? At the time (2004) there were no cost effective large 4 wheel disc brake kits available for our cars. Instead of waiting for the market to catch up, I used my employee discount and bought stuff from work. It took me a little while but I made it all fit the car. Best of all, I got 4 wheel disc brakes cheaper than the available (and smaller) front wheel disc brake kits.
[Re: jcc]
#1179936
02/17/12 06:00 PM
02/17/12 06:00 PM
feets
Senior Management
Senior Management
Irving, TX
A little bit of info about performance brakes for the uninitiated... Look at a good pair of brake pads (random pic): ![](http://www.jscspeed.com/images/catalog/category8478_thumb_full.jpg) See the beveled edges? That allows a smoother contact between the pad and rotor. When contact is made the ramped edge reduces the chance of the pad skipping and jumping. There's also less vibration. That means smoother and quieter braking. That cut down the center of the pad allows gasses, debris, and scrubbed off brake pad material an exit. Getting that stuff off the pad means the rest of the pad can do more work without the other stuff being in the way. Almost all of today's street oriented pads have backing materials that will reduce the friction between the back of the pad and the caliper. Again, this leads to smoother and quieter braking. Most of the brake squeal people hear comes from the pad vibrating against the caliper.
[Re: A57_RT ]
#1179939
02/17/12 06:48 PM
02/17/12 06:48 PM
feets
Senior Management
Senior Management
Irving, TX
Rotors are all kinds of confusing to some people.
Obviously, you need a vented rotor or you're simply not serious. Vented referrs to the fins between the inner and outer braking surfaces.
Drilled rotors can be iffy. The benefits are lighter weight, better cooling, and better venting of brake pad gasses and debris. The down side is that a poor quality rotor that is drilled after casting will often show stress cracks between the holes after heavy use. A quality rotor will have the "drilled" holes cast into them when the metal is poured.
Slotted rotors seem to be a bit of a step up from the drilled rotors. They offer the same benefits but don't crack as often as the low quality drilled pieces. Often, you'll find them drilled and slotted.
Many hard core race cars have gone to slotted ceramic rotors for the ultimate in light weight high heat brakes. An all-out effort like that is generally useless when cold but will toss you through the windshield when hot.
[Re: feets]
#1179940
02/17/12 06:50 PM
02/17/12 06:50 PM
jcc
Bitopia
Feets, I swear I am not targeting you, but this seems to be the month that you and I disagree, If you and I ever meet, I'll buy ![](/ubbthreads/images/graemlins/beer.gif)
I think the soon disappearing ramps are just for easier break in, all pads soon get to a square edge, and max pad surface area is the point anyway.
Reg "squeal", its telling you you need louder mufflers. ![](/ubbthreads/images/graemlins/grin.gif)
Do any real race or race type pads have ramps, and do they have ramps on trailing edges because installers are not smart enough, or because they want to reduce inventory by half in lieu of performance/pad life?
I see you replied after I edited my response, sorry I thought we were talking about real pads not squeal free street stuff. ![](/ubbthreads/images/graemlins/grin.gif)
[Re: jcc]
#1179941
02/17/12 07:05 PM
02/17/12 07:05 PM
feets
Senior Management
Senior Management
Irving, TX
Disagree all you like. Just do a little research first. The ramps are there for the reasons I stated. You will not find them on max-effort pads because chatter and squeal are expected. ![](http://cdn.vitalmx.com/photos/stories/2011/01/05/full_141534520_1294299992.jpg) Here's the EBC Green Stuff performance street brake pad: ![](http://www.ebcbrakes.com/Assets/greenpad.jpg) Here's the EBC Blue Stuff for road racing: ![](http://vr-speed.com/store/images/3882_1_lg.jpg)
[Re: A57_RT ]
#1179943
02/17/12 07:43 PM
02/17/12 07:43 PM
feets
Senior Management
Senior Management
Irving, TX
You may need to step up to a little bigger rotor. If you're under 3200 lbs I bet it's not by much. Since you're using Wilwood stuff you need to make sure your caliper is compatible with larger rotors. Some of the light weight stuff is thinner than regular rotors.
Try to get some air to the brakes. That will make a big difference if you're going to be running on road courses or longer duration events.
As for your brake pedal effort, many times you can get a difference in feel simply by changing to a different type of brake pad.
I assume this is a manual brake car. If you left the power pedal assembly in there and tossed the booster your pedal ratio will be off. That can increase pedal effort.
[Re: jcc]
#1179944
02/17/12 08:06 PM
02/17/12 08:06 PM
feets
Senior Management
Senior Management
Irving, TX
The idea behind multi-piston brake pads is for a more evenly distributed clamping force. The caliper is hard mounted and the pistons push from each side.
Older multi-piston calipers and those not intended for high performance driving have equal size pistons. That spreads the force evenly across the surface of the pad.
Larger high performance calipers have smaller leading pistons and larger trailing pistons. This puts more force on the trailing edge of the pad and helps prevent the pad from wearing on a taper. The leading edge of the pad lives a pretty harsh life and tends to get scrubbed more than the rest of the pad.
The bigger the caliper, the bigger your brake pad can be. That means there is more surface area for heat dissipation and longer pad change intervals.
Some calipers, like the 8 piston AMG stuff we're playing with have 4 brake pads per caliper. It acts like two separate brake calipers. The gap between the pads allows ventilation, debris clearing, and heat isolation from the rest of the pad material. Few cars use them. Even Mercedes has stepped back to 6 piston calipers using one large pad per side with the same (or more) friction surface as the 8 piston units. They're also a bit lighter. The caliper I sent to Oz weighed 15 pounds in an otherwise empty box. Weight kills.
There are a few 3 piston calipers out there. These are usually slider type calipers with pistons on one side.
[Re: feets]
#1179945
02/17/12 09:33 PM
02/17/12 09:33 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
bigger brakes don't give more braking power per-se, that's a function of tire grip. and yes, a stock 10.87" brake can overpower tire grip in some instances and cause lock up as easily as a monster 14" rotor.
but as feets alluded to, bigger brakes give better fade resistance due to better heat dissipation and absorbtion
[Re: patrick]
#1179946
02/17/12 10:23 PM
02/17/12 10:23 PM
Posts: 6,608 Indiana
EV2DEMON
The Camaro Kid
The Camaro Kid
Indiana
But there's more to it than that. Tire grip is only part of the equation. In addition to increased fade resistance, big brakes also offer a higher threshold of stopping before lock up. Tiny drum brakes have the ability to lock up, even with sticky tires, but that doesn't help stopping distances.
Big brakes offer the ability to slow rotation at a higher rate without locking up and therefore, retain traction & increase stopping ability.
When I put Stoptech rotors and calipers on the front of my car, I immediately realized that the antilock brakes engage far less often than with the stock brakes, even with the same tires. I never measured a before and after stopping distance, but I know I can drive deeper into turn 1 at Gingerman now..
[Re: EV2DEMON]
#1179947
02/18/12 04:29 AM
02/18/12 04:29 AM
A57_RT
Parts Problem
Parts Problem
If you left the power pedal assembly in there and tossed the booster your pedal ratio will be off. I had to chuckle a bit on that one ![](/ubbthreads/images/graemlins/no.gif) going on 28 years with this car it could have 3 diff ped setups. But to answer on the F-s its best to take all the parts from a manual brake car use the oem bracket actually I think the only way and have it work. But if you use the manual car parts, even the oem rod to the master can be used as some of the later Fs used the two bolt al.masters just a smaller dia unit then now. I will dig up and post what I have now specific rotor info and pad wise and see what you think I might do better with. Im at 8400 feet right now and jet for 7000-8500 as this is where I play the most, I ran up PP long ago in a 4 cylinder mopar, it would be fun to try in the old dodge....I wonder what short bursts of spray would do at the higer up straights??? But im pretty much done till spring, they have the roads soaked with mag, so untill a couple spring rains in june ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: Pale_Roader]
#1179949
02/18/12 12:25 PM
02/18/12 12:25 PM
A57_RT
Parts Problem
Parts Problem
I have 11 inch vented WW on the front, these in the pic in the back...I cant go bigger up front I dont think ot it may hit the rims??? What rotors would you upgrade to??? Anything here that would make this a good deal for anyone...??? Not mine or dont know who-s just local. http://denver.craigslist.org/pts/2829756987.htmlIf so I could go look, dicker, ect....
[Re: Pale_Roader]
#1179950
02/19/12 03:52 AM
02/19/12 03:52 AM
feets
Senior Management
Senior Management
Irving, TX
We rented a brand new 2008 Mercedes E-class Kompressor in Germany. That thing had (i believe) 18" wheels and the brakes filled the rim right to the edges. Looked like a 14" brake to me.
If it was an E-class with a Kompressor badge, it was probably an E55. However, they stopped production of the E55 in 2006. In 2007 it was the E63 with a naturally aspirated engine.
The E55 would have the same brakes, front and rear, and I have on the hot rod. The E63 had the same size rotors but a slightly smaller 6 piston caliper. It still fills up the 18" wheels.
[Re: feets]
#1179952
02/19/12 04:06 AM
02/19/12 04:06 AM
feets
Senior Management
Senior Management
Irving, TX
They wanted to be sure the air was blowing across the brake pads and rotor vents.
