70-72 A body. disc vs drum lower ball joint #1179861
02/17/12 12:33 PM
02/17/12 12:33 PM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
I`m looking at swaping a 10 drum setup for a kelsey hayes disc set up . What is the difference in the lower ball joints {I dont have the disc setup only E mailing to the guy that has the setup for sale } . He says the lowers are the same, I say no ,based on Rock auto and Moog sites ??? I sent him a picutre of mine he says they are identical. Are they that close?? The bottom bolt holes on spindle are 3 3/4 " a part and the lenght of steering arm seems to be 4 3/4 in lenght. The lower drums are as much as $125 on some sites where as the disc lower are alot 1/2 as much... must be some difference ??? HELP
Re: 70-72 A body. disc vs drum lower ball joint [Re: RTshaker] #1179862
02/17/12 12:35 PM
02/17/12 12:35 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
They are not the same, I have both setups and the moog and rock auto sites don't lie ... in this case .
Re: 70-72 A body. disc vs drum lower ball joint [Re: JohnRR] #1179863
02/17/12 12:58 PM
02/17/12 12:58 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
The difference between the two,is the mounting bolt hole diameter to the spindle.
1/2 inch diameter for the Drum brake ball joint.
9/16 inch diameter for the Disc brake ball joint.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 70-72 A body. disc vs drum lower ball joint [Re: hemi71x] #1179864
02/17/12 03:00 PM
02/17/12 03:00 PM
RTshaker Offline OP
RTshaker  Offline OP
Soooo if I really had to I could enlarge the hole in the drums ball to use my new balljoints on the disc spindle .... nothing else ??. Thanks
Re: 70-72 A body. disc vs drum lower ball joint [Re: RTshaker] #1179865
02/17/12 03:11 PM
02/17/12 03:11 PM
hemi71x Offline
hemi71x  Offline
Yep, that's correct.
Just drill them out to 9/16 diameter, and your good to go.
