Page 9 of 10 1 2 7 8 9 10
Re: Need photo 70 E-Body Backside of Dash Please. [Re: cataclysm80] #117960
02/11/09 10:39 AM
02/11/09 10:39 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I think the length on those is self adjusting. It starts out to long, then when you close the door the first time, the plunger slides inside the nut further.
Has anyone had problems with functionality/fitment of repops?
The plastic divider between the male terminals is pointless because both terminals are either grounded or not at the same time.
Tav
They are in common when grounded but they need to be isolated when the door is shut. Otherwise, the time delay lights illuminating the headlamp and ignition switches will come on every time the passenger door opens or the interior lamp switch on the panel dimmer comes on. Not a fatal error but just a fine detail.
Craig
Re: Need photo 70 E-Body Backside of Dash Please. [Re: cataclysm80] #117961
02/11/09 02:50 PM
02/11/09 02:50 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The plastic divider keeps the wires separated until the door is open. They keep them separated so the buzzer won't go off when you turn on the dome light with the dimmer switch. The original ones didn't have the divider because one of the wire connectors was insulated.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117962
02/11/09 05:50 PM
02/11/09 05:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi guys...I'll have to take another look at the map light operation when the car comes back out from the winter slumber...Mabe my switch is bad.. ...I've used a few of the aftermarket jamb switches...Both the "concours" and the normal repops and haven't had any problems with either... And yes they are adjustable...When you initially install the switch you need to put a piece of tape on the door frame so you don't chip the paint any more than nessesary...Then close the door slowly so the switch will adjust to the gap....
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117963
02/15/09 07:45 AM
02/15/09 07:45 AM
Poland
BartekP Offline
BartekP  Offline
Poland
Bad news:
The only time the Map light will work is when the dome and courtesy lamps, if you have them, are on.
i have to check it, but that is still not useful. Logically, map light should be able to switch on during driving without turning on the dome lamp as it disturbs the driver.
'70 Challenger SE '77 Dodge M880/W200 '08 Magnum R/T
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BartekP] #117964
02/15/09 01:22 PM
02/15/09 01:22 PM
Snoopy Offline
Snoopy  Offline
Logically, if that was the way it was suppose to work, Chrysler would have run a wire directly to ground instead of to the dome light switch. Better yet they would have used a switch that picked up it's ground through the switch housing and eliminated the extra wire and saved money.
Logically, they should have called it a Floor light rather than a Map light because all it was good for was lighting up the floor and the passengers feet.
So much for logic.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117965
02/19/09 10:59 PM
02/19/09 10:59 PM
Snoopy Offline
Snoopy  Offline
Does anyone have a good picture of the Headlight Delay Relay wiring harness for a 70 E-Body? From the wiring diagram, it looks like it only has three wires. P/N 2983710
Here is a wiring diagram I put together for the headlight delay wiring.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117966
02/25/09 02:57 AM
02/25/09 02:57 AM
Snoopy Offline
Snoopy  Offline
I updated the A01 drawing.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117967
02/25/09 10:54 PM
02/25/09 10:54 PM
cataclysm80 Offline
cataclysm80  Offline
Thanks Snoopy!
Tav
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117968
12/06/09 06:44 AM
12/06/09 06:44 AM
Poland
BartekP Offline
BartekP  Offline
Poland
So much for logic.
Finally I solved map light problem, that was too weird for me.
It works like I thought it should.
Map light & switch are mounted on lower plastic dash trim (A/C) so these are not grounded, but there should be special ground strap that goes to the dash.
Earlier I tried to ground switch housing just to try if that change anything and it didn't work.
That was another problem caused by loose element in the switch. Bottom isolator plate with electrical connections was not tight, I needed to crimp switch housing slightly. Between housing and isolator there is small metal tab that grounds one of the connections to the housing, it of course needs to have firm contact with housing.
I repaired the switch, made that special ground strap out of copper sheetmetal and it works.
map light function:
Switch ON - map light is on permanently, with dome on and off, with ignition on and off - so is true map light
Switch OFF - map light turnes on with dome and is just floor light
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BartekP] #117969
12/06/09 01:06 PM
12/06/09 01:06 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Perhaps these may be of help. These are from one of the DVDs that Beepbeep sent me about a year ago.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117970
12/06/09 01:08 PM
12/06/09 01:08 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
2
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117971
12/06/09 01:10 PM
12/06/09 01:10 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
3
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117972
12/06/09 01:11 PM
12/06/09 01:11 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117973
12/06/09 01:13 PM
12/06/09 01:13 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117974
12/06/09 01:15 PM
12/06/09 01:15 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117975
12/06/09 01:17 PM
12/06/09 01:17 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117976
12/06/09 01:18 PM
12/06/09 01:18 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
8
Re: Need photo 70 E-Body Backside of Dash Please. [Re: BJohnson] #117977
12/06/09 01:19 PM
12/06/09 01:19 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
9
Re: Need photo 70 E-Body Backside of Dash Please. [Re: ebodyseast] #117978
11/26/12 04:44 PM
11/26/12 04:44 PM
Germany
walkAbout Offline
walkAbout  Offline
Germany
Hi,
seems like all questions are answered, as there is no reply for such a long time. This is the best documented thread I came across, thanks to all, who contributed.
Many questions answered, where I was already sitting and thinking for a long time. Today I wanted to ask, where to put in the switch title light, which I got recently...
This is also answered already, now I have to find that strange connector above the radio or in the strapped wires there. I have the headlight/key in buzzer, found the pink 3 pin connector for the glove box light (but only the middle pin is a connector) and thought I have all the wires, but maybe I'm missing the harness used for the maplight, the switch panel bulb AND the steering column title lamp, and the time delay relay too.
CU
walkAbout
Re: Need photo 70 E-Body Backside of Dash Please. [Re: walkAbout] #117979
11/26/12 09:17 PM
11/26/12 09:17 PM
Harrisburg, Pa.
Harrisburg, Pa.
Wow, this is an old thread back from a long slumber... ...I see the map light dual circuit switch function was answered by that grounding strap...I knew the map light switch served double duty but forgot about the strap completing the circuit{thanks BartekP}...
WalkAbout, it sounds like you're missing the A01 light package harness...It connects all those components together...
Mods, any chance we can get this thread archived after it runs it's course ???
