Re: Need photo 70 E-Body Backside of Dash Please.
[Re: cataclysm80]
#117960
02/11/09 09:39 AM
02/11/09 09:39 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I think the length on those is self adjusting. It starts out to long, then when you close the door the first time, the plunger slides inside the nut further.
Has anyone had problems with functionality/fitment of repops?
The plastic divider between the male terminals is pointless because both terminals are either grounded or not at the same time.
Tav
They are in common when grounded but they need to be isolated when the door is shut. Otherwise, the time delay lights illuminating the headlamp and ignition switches will come on every time the passenger door opens or the interior lamp switch on the panel dimmer comes on. Not a fatal error but just a fine detail. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Snoopy]
#117968
12/06/09 05:44 AM
12/06/09 05:44 AM
Posts: 36 Poland
BartekP
Poland
Logically, if that was the way it was suppose to work, Chrysler would have run a wire directly to ground instead of to the dome light switch. Better yet they would have used a switch that picked up it's ground through the switch housing and eliminated the extra wire and saved money.
Logically, they should have called it a Floor light rather than a Map light because all it was good for was lighting up the floor and the passengers feet.
So much for logic.
Finally I solved map light problem, that was too weird for me. It works like I thought it should.
Map light & switch are mounted on lower plastic dash trim (A/C) so these are not grounded, but there should be special ground strap that goes to the dash. Earlier I tried to ground switch housing just to try if that change anything and it didn't work. That was another problem caused by loose element in the switch. Bottom isolator plate with electrical connections was not tight, I needed to crimp switch housing slightly. Between housing and isolator there is small metal tab that grounds one of the connections to the housing, it of course needs to have firm contact with housing.
I repaired the switch, made that special ground strap out of copper sheetmetal and it works.
map light function: Switch ON - map light is on permanently, with dome on and off, with ignition on and off - so is true map light
Switch OFF - map light turnes on with dome and is just floor light
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
[Re: ebodyseast]
#117978
11/26/12 03:44 PM
11/26/12 03:44 PM
Posts: 35 Germany
walkAbout
Germany
Hi, seems like all questions are answered, as there is no reply for such a long time. This is the best documented thread I came across, thanks to all, who contributed. Many questions answered, where I was already sitting and thinking for a long time. Today I wanted to ask, where to put in the switch title light, which I got recently... This is also answered already, now I have to find that strange connector above the radio or in the strapped wires there. I have the headlight/key in buzzer, found the pink 3 pin connector for the glove box light (but only the middle pin is a connector) and thought I have all the wires, but maybe I'm missing the harness used for the maplight, the switch panel bulb AND the steering column title lamp, and the time delay relay too. CU walkAbout
[Re: walkAbout]
#117979
11/26/12 08:17 PM
11/26/12 08:17 PM
Posts: 7,200 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Wow, this is an old thread back from a long slumber... ...I see the map light dual circuit switch function was answered by that grounding strap...I knew the map light switch served double duty but forgot about the strap completing the circuit{thanks BartekP}... WalkAbout, it sounds like you're missing the A01 light package harness...It connects all those components together... Mods, any chance we can get this thread archived after it runs it's course ???
