spark plugs #1179355
02/16/12 02:21 PM
02/16/12 02:21 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
hi i need some help please. i have a 572 with 440-1 heads 14.98 c.r. i am wondering what is a good plug heat range to use ? i have ngk -10s now suggested by the guy that did my heads . just wondering what others are using ? thanks
Re: spark plugs [Re: Rich970] #1179356
02/17/12 11:31 AM
02/17/12 11:31 AM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
Re: spark plugs [Re: Rich970] #1179357
02/17/12 01:27 PM
02/17/12 01:27 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: spark plugs [Re: Dodgem] #1179358
02/17/12 02:46 PM
02/17/12 02:46 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
thank you Dodgem
Re: spark plugs [Re: Rich970] #1179359
02/17/12 04:18 PM
02/17/12 04:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
which fuel, race gas, E85 or ?
Re: spark plugs [Re: Cab_Burge] #1179360
02/17/12 04:40 PM
02/17/12 04:40 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
i am running c14. with .92 jets
Re: spark plugs [Re: Rich970] #1179361
02/18/12 12:02 PM
02/18/12 12:02 PM
NC
440Jim Offline
440Jim  Offline
NC
An NGK -10 is pretty cold.
No hotter than a -9, IMO.
So, keep an eye on them when running and adjust accordingly.
If you run the -10, tune the idle and pit driving to avoid loading them up too much.
Cross reference:
Other possible spark plugs:
NGK: R5671A-10
Autolite: AR3932
Champion: C57CX
Re: spark plugs [Re: 440Jim] #1179362
02/18/12 06:02 PM
02/18/12 06:02 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run the Champion C59CX in mine,was told by Indy the 59 would be better than the 57 in my engine on alcohol. Next time I order I think I will get a set of each 57 & 59 to try.
I have not run the Autolite's yet but the cross over from the C59CX is AR3933.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: spark plugs [Re: 440Jim] #1179363
02/19/12 12:03 PM
02/19/12 12:03 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
thanks i will try the -9 ngk .
Re: spark plugs [Re: MRMOPAR622] #1179364
02/19/12 12:11 PM
02/19/12 12:11 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
do you need to run a hotter plug with alcohol ?
Re: spark plugs [Re: Rich970] #1179365
02/19/12 02:46 PM
02/19/12 02:46 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Indy says the C59CX plug was the best for both alcohol and gas. I also had thought that with alcohol a colder plug would be best and I think I may just try it and see this year.I will only be out a couple of $$$ to put a set in and make a pass to see which is best. I have been having to order the plugs from Indy,but was told @ Advance they could order the plugs for me. Unlike most I don't have a problem with Indy but Advance is only a couple of miles up the road and no min. or shipping charges.
Re: spark plugs [Re: MRMOPAR622] #1179366
02/19/12 11:24 PM
02/19/12 11:24 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
c59cx is a -9 in ngk thats what i going to try . i think the -10 ngk never get enough heat in them to get clean. thanks
