Page 2 of 3 1 2 3
Re: wheel spacers [Re: dangina] #1178415
02/16/12 08:25 AM
02/16/12 08:25 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
May I take this opportunity to remind everyone that this is the going fast in the corners forum and items like wheel spacers are a big NO NO on cars put under duress or driven as transportation.
It's called making good decisions and safety, not looking cool.
I wish I was a moderator as I would nuke this thread.
Re: wheel spacers [Re: ThermoQuad] #1178416
02/16/12 08:55 AM
02/16/12 08:55 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
May I take this opportunity to remind everyone that this is the going fast in the corners forum and items like wheel spacers are a big NO NO on cars put under duress. It's called good decisions and safety.
I would have to agree on this one... but i also have to admit i have only a 'hunch' to go on. A hunch is not enough for me.
I have been to a good handful ov serious wheel/tire/chassis guys and brought this up. Mustang 17 & 18" rims are cheap and plentiful... and not everyone can afford real rims. Spacers come up a LOT in casual conversation. Every single one ov these guys uses, has used or even recommends these things (bolt-on billet hub-centric spacers). The rock-crawler and 44" mudder testimonies are always brought up, and to everyones satisfaction, but it still doesn't sit well somehow, with me. If a truck hub fails its not usually at 100+mph, and any abuse those monster rigs see is always off-road. Cars WILL get flogged on public roads, mine will see a lot ov canyon fun... so the hub-spacers scare me a bit.
Still... for $200 i can mount ANY cheap wheel i can find, with a perfect offset. Mighty tempting. The above poster (not Tom) mentioning no Google-search mentions ov failures is interesting though... certainly something would have come up, and you know it would be mentioned online.
Hmmm...
Re: wheel spacers [Re: ThermoQuad] #1178417
02/16/12 10:31 AM
02/16/12 10:31 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I can definitely see their limitation, especially if you're coming at it from someone like Tom, who's on a track going 150+ MPH.
BUT a good quality billet adapter isn't something that is going to fail. I'd trust a good quality billet adapter allowing the use of good quality wheels (i.e. my OEM mustang rims cast here in the USA) than any of the offshore cast wheels that our out there that may have the proper offset.
for typical driving, and even autocross, I've never seen a failure of good quality, bolt on adapters. if there was a failure, I'd bet money it was due to, as previously mentioned, the adapters not properly torqued and the lugs backed off. of course, that can happen with an aluminum wheel even without an adapter, too.
2017 Grand Cherokee Overland
Re: wheel spacers [Re: ThermoQuad] #1178418
02/16/12 09:31 PM
02/16/12 09:31 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I don't see the problem as a lot of drifters use spacers on their cars pushing upwards of 300-600 hp and the whole sport relies on you going sideways through corners and I have yet to see one fail...
Re: wheel spacers [Re: patrick] #1178419
02/16/12 09:34 PM
02/16/12 09:34 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i don't really get it either... even custom spaced wheels have a spacer built into the hub since alot of these wheels have a positive offset. the spacer is just cast as part of the wheel. if you add a good spacer, one thats machined from billet vs a cast one i think you'd be ok. the billet spacer would be just as strong as the wheel itself. ultimately the only difference i see is that the nut is not interacting higher up on the stud and not at the base which could ultimately overload the stud, but thats a heck of alot of force needed.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: wheel spacers [Re: dangina] #1178420
02/16/12 09:50 PM
02/16/12 09:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've yet to see a DRIFTER catch traction in a corner.
Don't be the exception.
Re: wheel spacers [Re: Supercuda] #1178421
02/16/12 11:38 PM
02/16/12 11:38 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I have seen A LOT of autocrossers using them, too
Re: wheel spacers [Re: patrick] #1178422
02/16/12 11:54 PM
02/16/12 11:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Do a search on Ruf Porsche 930...
Might even add 21mm (3/4") to your search... If Ruf finds them acceptable for a car like the 930..... I think most folks on Moparts aren't gonna have an issue...
Re: wheel spacers [Re: 1_WILD_RT] #1178423
02/17/12 02:50 PM
02/17/12 02:50 PM
NC
P
phil4161972 Offline OP
P
NC
Thanks for all the response. I still dont know if I want to try spacers out or not but it has been an interesting read.
Re: wheel spacers [Re: ThermoQuad] #1178424
02/17/12 03:09 PM
02/17/12 03:09 PM
Here
jcc Offline
jcc  Offline
Here
May I take this opportunity to remind everyone that this is the going fast in the corners ..........
I have shared your discontent many times, however to steer away as far as possible from a "corner carvers" website mentality , I follow the original Can Am rule, there are no rules.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: wheel spacers [Re: jcc] #1178425
02/17/12 04:27 PM
02/17/12 04:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Im gonna run some 1/4" spacers this summer in the front. Already have Mustang wheels and they are lug centric on my Dodge anyway so guess what, a spacer isnt gonna change squat.....
Mopar to the bone!!!
Re: wheel spacers [Re: 72Swinger] #1178426
02/18/12 10:22 AM
02/18/12 10:22 AM
ThermoQuad Offline
ThermoQuad  Offline
Imo the word autocross is not a good word on here.
Autocross is child's play compared to running high speed laps. [Mitch this is not directed at you and your talent] Then again a wheel spacer would shows it colors under the duress of autocross...
The whole concept of corner carving is to take these old cars we drive and make them drive better everywhere. Very few people on here have the $$$$$$$$$$$ to race let alone run 2 days on the road course in a driving school. It costs $650.00+ for 2 days at the track. Fuel, food, gas, oil, motel, $420.00 entry fee...now add the cost of what was spent on the car.
I don't care who uses wheel spacers on their expensive cars, as they "engineered" the spacers into the concept. For us it's a bad concept and a compromise. Then again if you are building a show car that looks like it might take a corner fast then wheel spacers are fine.
Re: wheel spacers [Re: phil4161972] #1178427
02/19/12 10:43 AM
02/19/12 10:43 AM
central CT
cudazappa Offline
cudazappa  Offline
central CT
I've run 1" and 1.25" spacers on my car.
I've never used the "shim" slip on type, only the solid 6061 with high quality studs. that bolt onto the hub type (and then you mount your rim on the spacer)
I've never had a problem with them.
On the street, never an issue. Unbolt the street tires, put on my Autocross DOTs, drive to the event, drive the car hard for about a minute at a time, average day 6 runs, and drive home. Change back to street tires. Every time the rims are off I will check the torque on the spacers with my calibrated torque wrench (because I'm paranoid). Suffice to say, I've never had to re-torque them, everything stays put at 100ft/lbs.
Now for the sake of argument, I broke out my old statics and dynamics books and drew the free body diagrams for both a 0 offset wheel and 1" offset wheel with a 1" spacer.
Using the normal FBD as the given, I compared it to the offset FBD. At the wheel hub, there is a different torque moment. However, the spacer transfers the forces of the 1" offset wheel into the hub like a normal 0 offset wheel.
This is much like Feets custom wheels he had made with the extra 1.25" boss forged onto the back of the hub.
However that's in static, and assuming the wheel will not see forces that will flex it. Dynamics could play a role on the outer wheel bearings as there's an additional torque from the longer lever arm now attached to the hub.
AndyF, care to check that? I think I'm right. I'm even going to double check with my old prof on Tuesday.
And the only reason why I currently use spacers is that I don't have the coin for nice forged 17x9s. Genuine Ford rims are the best choice for me now, it just does get annoying with 40 lug nuts rather than 20.
1971 Challenger
Re: wheel spacers [Re: cudazappa] #1178428
02/22/12 09:36 PM
02/22/12 09:36 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
I run 'em on my G35 (15mm ones); no problem.
Older 911 turbos used them from the factory.
Just get good quality, billet, bolt-on types for anything 1" or larger.
Re: wheel spacers [Re: 2fast4yourBrain] #1178429
02/23/12 01:19 AM
02/23/12 01:19 AM
Canada
MUSLCA Offline
MUSLCA  Offline
Canada
I ran a set of 2.5 inch wide adapters on my 2001 GMC Sonoma for a year
with absolutely no issues. It's quite common theses days.
Re: wheel spacers [Re: MUSLCA] #1178430
02/23/12 01:21 AM
02/23/12 01:21 AM
Canada
MUSLCA Offline
MUSLCA  Offline
Canada
Then I used them on my Jimmy for another year.
Same thing, no issues.
Re: wheel spacers [Re: MUSLCA] #1178431
02/23/12 01:24 AM
02/23/12 01:24 AM
Canada
MUSLCA Offline
MUSLCA  Offline
Canada
That's how I was able to fit a 17x8.5 Corvette rim on these
vehicles.
Re: wheel spacers [Re: MUSLCA] #1178432
02/23/12 07:22 AM
02/23/12 07:22 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Come to think ov it, my 68 Caddy hearse actually came with factory spacers... not adapters, but actual spacers to slip over the long-shanked lugs (not threaded through the spacer). This was to bring the rear track out to the quarters as those commercial chassis' are widened. The spacers are about 2" each, and made ov solid iron. I was going to try and find a way to replace them with something lighter, as they weigh a ton... but i figure with a vehicle ov that size... probably best to leave the iron in place.
Not that these cars were expected to slalom or skidpad all that well... but still... 'factory' cars are usually over-engineered in the name ov safety...
Re: wheel spacers [Re: Pale_Roader] #1178433
02/23/12 08:53 AM
02/23/12 08:53 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the biggest issue with the cheap cast spacers is that they can crack. Sometimes they are not flat from the casting process and when you torque your wheel down and flatten them out the part disintegrates only to be let go while driving, causing a very dangerour situation. now if you buy billet machined spacers usually made from 6061 and they are machined hub centric to fit your wheels and your rotor hub, you will be miles ahead. there is no reason that these don't act like an extension of the wheel. and in fact if you use a hub centric spacer, it may even strengthen the wheel hub joint as opposed to your lug centric wheels alone.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: wheel spacers [Re: Jerry] #1178434
03/02/12 11:17 PM
03/02/12 11:17 PM
Canada
MUSLCA Offline
MUSLCA  Offline
Canada
no other choice but billet adapters, strong as heck.
Page 2 of 3 1 2 3
