Re: Need photo 70 E-Body Backside of Dash Please.
#117840
09/12/08 12:27 PM
09/12/08 12:27 PM
Posts: 7,197 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
How about this.
yups thats what mine looks like. and it looks like it does just hang there. what a riot!
And that time delay also is used for the seatbelt light in overhead console equipted cars...Keeps the seatbelt light on a few seconds after the doors are closed.. Does anyone have a pic of the actual headlight delay relay in Snoopy's original pic ???? I tried for the headlight delay and it did'nt work...I think mine is missing from that upper cowl location so I'll have to go back through my electrical parts and see if I forgot to install it {If I know what I'm looking for }....
[Re: screamindriver]
#117841
09/12/08 03:52 PM
09/12/08 03:52 PM
Posts: 500 NoVa
ebodyseast
NoVa
does this pic from '70 Plymouth FSM help anyone? Or is this the A/C delay relay Snoopy mentioned earlier.
#117842
09/12/08 04:11 PM
09/12/08 04:11 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
This is the only picture of a headlight delay relay that I have. It is labeled as a 70, but I can't confirm. The parts book calls out a relay with a bracket for 71, but not 70. Did the 70 have a built in bracket? If you know what this relay is for, let me know so I can rename the photo.
It turns out this is a Low Fuel Relay.
[Re: ebodyseast]
#117843
09/12/08 04:11 PM
09/12/08 04:11 PM
no, thats for the AC system.
Ive searched the FSM hi an lo and the headlight delay relay location is not shown...
[Re: Snoopy]
#117846
09/12/08 04:35 PM
09/12/08 04:35 PM
screamindriver
Harrisburg, Pa.
Snoopy,I think ebodyseast called it... That relay in the pic looks like the low fuel relay for the overhead console "low fuel" indicator..Here's a comparison pic... And a pic of the low fuel relay in it's position on the dash frame,passenger side next to the glovebox liner...Note the connector in this one...It sure looks like the same terminal configuration as your pic... ![](http://i46.photobucket.com/albums/f131/Screamindriver/lowfuelrelaylocation-1.jpg)
[Re: Snoopy]
#117850
09/12/08 05:08 PM
09/12/08 05:08 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
jrwoodjoe From the Plymouth Factory Service Manual Fig 26 Try this diagram.
Thanks..that's the one. Joe ![](/ubbthreads/images/graemlins/bow.gif)
[Re: Snoopy]
#117851
09/12/08 05:18 PM
09/12/08 05:18 PM
Posts: 500 NoVa
ebodyseast
NoVa
You guys put some great stuff out to help out Joe, this is his thread so thanks Joe, also hate to hear about your daughter...best of luck & hope great news is right around the corner waiting for you guys... ![](/ubbthreads/images/graemlins/thumbs.gif) I may have a unique harness & options + missing items so my problems may be confusing to others and to myslf. My car has the A01 option, but no headlamp relay, and no harness. Still like to see what one looks like. It must be secured by a bracket & screw by the looks of the pics posted. Like sceamindriver, I'm looking through my electrical parts to help anyone else here out too.
[Re: ebodyseast]
#117857
09/12/08 06:42 PM
09/12/08 06:42 PM
Posts: 500 NoVa
ebodyseast
NoVa
I also found that the headlamp warning buzzer connector on my harness isn't plugged into anything, anyone got a pic of a headlamp warning buzzer. The connector is two reds and two blacks/yellow tracers and is just above the turn signal and ignition steering column connectors in the harness.
