Page 2 of 10 1 2 3 4 9 10
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Finoke] #117820
09/10/08 02:42 PM
09/10/08 02:42 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
Nice Tom!
Joe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117821
09/10/08 03:43 PM
09/10/08 03:43 PM
A01 = Light Package:
Glove Box Lock, Map/Courtesy Light, Reading And Dome Light, Glove Box Light, Ash Receiver Light, Trunk Compartment Light, Hood/Fender Turn Signal Lights, Ignition Switch Light With Timer, Headlight On Buzzer And Headlight Switch Light With Timer.
well since we're on the subject, I have the A01 option in my cuda and I have the headlight buzzer and headlight delay. I noticed that there is a red wire coming off the timer that NEEDS to be plugged into BATTERY for the time to work. does anyone know where this connection is made. right now its plugged into the BAT terminal on the fuse block.
Re: Need photo 70 E-Body Backside of Dash Please. #117822
09/10/08 03:54 PM
09/10/08 03:54 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
cucu
Where is the timer located?
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117823
09/11/08 08:20 AM
09/11/08 08:20 AM
cucu
i actually checked the service manual last night. fig 26 shows it all.
I have 2 green wires going into a female bullet type connector. the male side is a yellowish wire that goes into a fuse holder. comes out the other side into a harness with a small black wire the red wire. thsoe wires go to the headlight relay up under the left side cowl area. the other side of the red wire that goes to the relay goes to the BAT terminal on the fuse block. the other side of the small black wire goes to an accessory feed under the dash (one of those 3 terminal black connectors with a tan wire on it).
the timer is a little cylinder looking thingy (looks like an old flourescent light starter) and is just shoved up under the dash
Re: Need photo 70 E-Body Backside of Dash Please. #117824
09/11/08 08:46 AM
09/11/08 08:46 AM
Tenn.
Tenn.
cucu
Snoopy, here is a photo of it from my harness. This should be the timer.
Joe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117825
09/11/08 12:48 PM
09/11/08 12:48 PM
Hudson Valley
conv440 Offline
conv440  Offline
Hudson Valley
Since we're showing off dashboards...
Can I play too?
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117826
09/11/08 01:27 PM
09/11/08 01:27 PM
Snoopy Offline
Snoopy  Offline
Chris,
It's no wonder you are having problems, your dash is upside down. Here you go buddy, this should make it a little easier to get it right.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117827
09/11/08 01:35 PM
09/11/08 01:35 PM
Snoopy Offline
Snoopy  Offline
cucu & Joe
I asked about the location of the timer because there are two time delay relays, not counting the A/C, and I was trying to determine exactly which one cucu was asking about.
I appreciate the info you both supplied.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: conv440] #117828
09/11/08 01:56 PM
09/11/08 01:56 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Can I play too?
You can play! Very nice
Re: Need photo 70 E-Body Backside of Dash Please. #117829
09/11/08 02:18 PM
09/11/08 02:18 PM
Hudson Valley
conv440 Offline
conv440  Offline
Hudson Valley
cucu
Cucu, I am very surprized to hear that Chrysler just shoved the time delay can up under the dash where it would rattle around and drive everyone nuts. I was expecting it was mounted in a clip like the turn signal relay is mounted to the ash tray. I checked my service manual and there is no diagram showing how to install it.
Snoopy, thanks for straightening me out. No wonder it wouldn't fit right when I tried to install it in the car.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: conv440] #117830
09/11/08 03:51 PM
09/11/08 03:51 PM
cucu
well, let me rephrase that- it was shoved up under the dash and wrapped around someof the harness when I GOT IT. most likely not like that when it came from the factory. my wiring was hacked to hell and back when I got my car.
If anyone knows where its SUPPOSED to be mounted, I'd love to put it in its correct location.
Re: Need photo 70 E-Body Backside of Dash Please. #117831
09/11/08 06:28 PM
09/11/08 06:28 PM
Snoopy Offline
Snoopy  Offline
See if this helps.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117832
09/11/08 09:48 PM
09/11/08 09:48 PM
cataclysm80 Offline
cataclysm80  Offline
I am going to use the glovebox light though. Can it go into the same orange feed that feeds the gauge lights and the cigarette lighter bulb or should it plug in elsewhere? Based on the photo above it looks like it may go into the 3 way pink plug.
Thanks, Joe
If I recall correctly, the lights fed by orange wires use a switched power, and the lights fed by pink wires use a switched ground. If you swap them around they don't quite work right.
In this example, the orange power feed wire is switched by the headlight switch, so those lights are only lit when you have the switch turned on.
The glovebox light (having a pink wire) should have power all the time, but is only lit when it recieves a ground from the glovebox switch (door open).
If you were to plug the glove box light into the orange power feed, it would only be lit when it had both ground AND power, meaning that it would only light when the glove box door was open, AND the headlight switch was on.
If you don't feel that you'll need the glovebox light in the daytime, this may be a workable solution for you, but I'm pretty sure the factory had it plugged into a pink wire feed.
By the way, your dash looks great!
Tav
Re: Need photo 70 E-Body Backside of Dash Please. [Re: cataclysm80] #117833
09/11/08 10:20 PM
09/11/08 10:20 PM
Tenn.
Tenn.
Hey TAV. Those were my thoughts also..I think it plugs into the 3 way feed that has the pink and gray wire.
Snoopy, I've looked at all the wiring diagrams but for the life of me, I do not see the glovebox light wiring in any of them. I must be missing something.
Joe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117834
09/11/08 10:56 PM
09/11/08 10:56 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Didn't read this till tonight, plug the glove box light's pink wire into any one of the three pink accessory feeds.
I think the relay hangs free in space & doesn't rattle at all.
Hey cucu...can you please post a pic of what your A01 harness looks like, the one with the fuse holder. I'd like to check to see if mine is identical and ready to go. I think I have to find where that yellow bullet connector gets plugged into from the posted pic of the relay above too.
Cool bro...thanks for the info Tav & good luck guys, the dashes look dynamite...
Re: Need photo 70 E-Body Backside of Dash Please. [Re: ebodyseast] #117835
09/12/08 12:17 AM
09/12/08 12:17 AM
Snoopy Offline
Snoopy  Offline
jrwoodjoe
From the Plymouth Factory Service Manual Fig 26
Try this diagram.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117836
09/12/08 12:48 AM
09/12/08 12:48 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
See if this helps.
Thats the Headlight Delay Relay which keeps your headlights on if you turn them off after turning the ignition off...The Delay Relay shaped like a flouresent lamp starter being discussed is for the key switch/headlight switch lamps...
Re: Need photo 70 E-Body Backside of Dash Please. [Re: 1_WILD_RT] #117837
09/12/08 01:34 AM
09/12/08 01:34 AM
Snoopy Offline
Snoopy  Offline
How about this one. Item "J". It looks like it might be taped down to the wiring harness. Maybe someone can take a look on an unmolested car?
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117838
09/12/08 02:44 AM
09/12/08 02:44 AM
Snoopy Offline
Snoopy  Offline
How about this.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117839
09/12/08 08:18 AM
09/12/08 08:18 AM
How about this.
yups thats what mine looks like. and it looks like it does just hang there. what a riot!
