Re: 42RH overdrive transmission upgrades and install
[Re: gdonovan]
#1175811
02/10/12 08:50 AM
02/10/12 08:50 AM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
For those wondering about the application- The car is a 1974 Duster (3640 lbs with driver) with a late model 5.9 (windage tray, Enginequest heads, Edelbrock RPM intake, Comp .505 lift cam, exhaust manfilds with duals) formerly with a 904 trans and a 8.25 rear with 3.55 gearset.
At LVD the car ran 14.2 at 94 mph with the old POS cam which was replaced last fall. I might also toss the 318 exhaust manifolds while I'm at it too this month and install some 340 ones.
The goals for the trans swap are better low end grunt (2.74 first gear vs 2.45 plus improved converter) better mpg on the highway, less cabin noise at cruise (2300 rpm vs 3500 rpm) and higher top speed.
The 42RH will add 50 pounds to the car, but I picked up some Feather Duster bumper brackets to offset the increase. The factory steel pieces are HUGE!
I'm going to do a page on my site detailing the transmission upgrades and install for anyone also looking to take this path.
Before anyone chimes in about the Gear Vendors unit- I have no interest in it due to cost, available overdrive ratio and the fact it doesn't (or can't) provide a lock up feature. Not bashing, it is nice to have options but it just isn't a fit for what I'm doing.
Gary
[Re: BRONZEBEE]
#1175814
02/10/12 10:37 AM
02/10/12 10:37 AM
gdonovan
Oakdale CT
You will need a 360 weighted converter for a500,Precsion converters in Iowa has them part# 5346 you can get in a higer stall if needed.
Nope, already been using a magnum flexplate which has the balance built into it. I'm all set on the converter selection but I'll keep the information in case I go a different route in the future.
As far on the overdrive unit your builder can get a a518 overdrive dirct clutch drum to upgrade for more clutches,you can add to the overdrive clutches without a problem.
I'm the builder (Chrysler trained) and already have two 46RE overdrive units, 46RE is the later A-518 =)
Thanks! Gary
[Re: BRONZEBEE]
#1175815
02/10/12 10:43 AM
02/10/12 10:43 AM
gdonovan
Oakdale CT
I'm sure there will be others will tell you go 518,but the a500 is a very good unit.
I'd rather have the 42RH as it is lighter, less hp loss and has a better 1st gear ratio in my honest opinion.
For my 5.9 it will just do just fine, not a full out race car and if it breaks into the 13's while knocking down 20+mpg with the a/c on I'll be perfectly content.
[Re: roadrunninMark]
#1175819
02/10/12 11:02 AM
02/10/12 11:02 AM
gdonovan
Oakdale CT
I will be watching your progress as I am going to use a A518 eventually in the bcuda. How are you going to handle the shifting to OD and the lockup convertor, pressure switches? Please include all that info and any wiring in your pages, thanks!
I'm looking at two paths- The simple one is pressure switches at first but I'm looking into a small-micro computer that can be programmed. Utlizing a map sensor and a few other minor pieces it should not be a big deal to come up with something a bit more elegant and there is no shortage of stuff under $100 if not less.
[Re: 70AARcuda]
#1175824
02/10/12 03:33 PM
02/10/12 03:33 PM
gdonovan
Oakdale CT
you will find that the overdrive unit on the 42rh is the same as the 46rh, just the number of disc used is different along with the thickness of the pressure plate ...a thinner pressure plate is used in the 46rh to allow more clutch disc.
Yup, I'm just going to rob the parts I need from them for my unit (which is aready clean and ready to go)
Some units do have stouter gearsets but for this application I'll not be needing them.
[Re: BRONZEBEE]
#1175826
02/10/12 08:33 PM
02/10/12 08:33 PM
gdonovan
Oakdale CT
i have put 904's with the low first gear behind 408 strokers and never had a problem,i don't see why a a500 is any different and if you talk to a torque converter guy he will tell you that there is a converter application for a 360 with weights for the a500
As I already have pointed out- I'm running a magnum flexplate that already has the weights attached. I can run any neutral balance converter that will work with a 42RH.
Indeed, I have been running it with the 904 for the last 2 years with a stock 318 converter.
#1175828
04/29/12 07:20 AM
04/29/12 07:20 AM
gdonovan
Oakdale CT
Just went on the first road test last night on the cruise to Berlin, here is what I posted over at the A-bodies forum.
Success!!
Just back from the cruise to Burger King on the Berlin Turnpike and the car was great!
The lower first gear set (2.74 vs 2.45) and slightly looser converter have noticeable snap off the line, it bangs through the gears with authority and cruise is simply a joy! The overdrive and lockup have lopped over a 1000 rpm off at cruise, where before I was buzzing the hell out of the motor at 65 mph now it turns a leisurely 2000 rpm while cranking along at 80 mph! For once I was passing everyone on the highway instead of being passed all the time!
The sweet spot is between 75-80 mph, the car is just loafing along, very little pedal is needed to maintain speed and the cabin noise is notably less. Very simple to toggle the overdrive and lockup on and off and compare the changes. I have it wired so that lockup and overdrive comes in at the same time, very simple and works great. The motor doesn't seem to mind the load at all till around 1400 rpm or so. 1500 rpm and up and it just pulls away on the highway & state roads.
Car has a few nitpicks like a rattling exhaust and minor pan leak (I need to get rid of the crappy NAPA gasket and get the real Mopar one) and I have to tweak the valve body as it likes to shift a touch later than I'd like at light throttle...
EDIT- Problem was a bent kickdown rod hitting the bellcrank for the column shifter, all fixed!
There is utterly NO harshness or vibration caused by the Chevy trans mount, it worked like a charm.
All in all I'm very pleased with the upgrade, I'll try and post a trans build up soon. Go for the upgrade! This is an awesome mod for our old Mopars!
Gary
P.S. For upgrades the transmission got a aluminum accumulator, 4.2 shift lever, 5 clutch front drum from a 44RE and a Transgo shift kit that I had on the shelf for 5 years.
"I think its got a hemi"
