Re: Neutral safety switch--------------Where to find one??? [Re: bboogieart] #1175199
02/10/12 11:57 AM
02/10/12 11:57 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Later switch. The later comb has an extra contact point to turn on the back up lights. So yeah now you can see the rooster comb would need to be replaced as well, as the extra point for reverse is between the park and neutral. Basically this comb is longer and has an extra tab. Just swap both and eliminate the back-up light wires from the system. I suppose the valvebody might need to be switched as well(?)
When the weather gets warmer, I will pull both apart and see just what needs to be done.
Still, never say can't , say how .
Of course the $45.oo dollar price isn't looking as bad. Might get a couple of those myself. Don't see 'em getting any cheaper.
I have mechanical Aptitude.
I can screw up anything.
Re: Neutral safety switch--------------Where to find one??? [Re: moparjo68] #1175200
02/10/12 12:32 PM
02/10/12 12:32 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
But if this tranny was being placed into a 69 or 70 Mopar, wouldn't the three pin NSS be used instead of the one prong??
If you are putting it into the later body style then yes the three prong plug needs to be used. If you are useing an older tranny this would need to be changed anyway or you would not have back up lights.
Pretty much renders the rest of my posts moot huh? At least you learned what a rooster comb is. I learned a little too. That's why I come here. I am always running off and doing things that can't be done.
Re: Neutral safety switch--------------Where to find one??? [Re: bboogieart] #1175201
02/10/12 02:04 PM
02/10/12 02:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The rooster comb is simply the name for the trigger for the switch.
Look at the picture of the three levers (rooster combs) and the switchs below each one. You can see that there are two legs that work the first switch ,a notch and a leg for the second switch and a ramp for the third three prong style. You can see that they will not work if switched around. The switchs screw into the trans at different depths also. They won't work unless they are matched sets lever and switch.
You contardict yourself with this last statement. You said it can't be done, and then explain how they can. Hmmm.
Here is the picture that is in the tech archive article.
Although they look different. it appears as though any could be used. The last comb seems to have a high spot where the middle one has a valley, that high spot would be for the back-up lights. After the neutral both combs ramp down to release the switch. For the sake of not having to do it twice I might just replce the rooster comb as well. Here is the picture that is in the tech archive article.
The first one was for pusg button trans the second one is the 66 thru 68 switch and the last one is the 69 & later switch
I Did not conterdict myself.I was addressing the fact you can't swap styles of switchs without swapping levers. Which was for the benefit of the original poster from whom you highjacked this thread.
Re: Neutral safety switch--------------Where to find one??? [Re: stumpy] #1175202
04/01/14 06:23 AM
04/01/14 06:23 AM
Louisiana
sparkzz Offline
sparkzz  Offline
Louisiana
Hello,
Can anyone tell me where I can get the "comb" for the 3 prong NSS for the A727 transmission, and what is it really called?
I have a '94 B250 van with backup light issues, and that may be the problem.
I have searched all over and was fortunate to find this thread.
Thanks.
Re: Neutral safety switch--------------Where to find one??? [Re: sparkzz] #1175203
04/01/14 03:39 PM
04/01/14 03:39 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The factory name for the roostercomb or cockscomb is "Lever, Manual Valve".
What is the issue with the BU lights? If they stay on in every gear, the plastic shoe is broken/missing...can't think of any other issue that would be the roostercomb's fault.
Re: Neutral safety switch--------------Where to find one??? [Re: bboogieart] #1175204
04/01/14 03:50 PM
04/01/14 03:50 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC member Joesix pack has them.He should have them in the parts section.I know there was at least 1 listed last month.Rocky
Chrysler Firepower
Re: Neutral safety switch--------------Where to find one??? [Re: therocks] #1175205
04/01/14 07:19 PM
04/01/14 07:19 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
dont have any of the combs, try CRT for internal loose trans parts...
Re: Neutral safety switch--------------Where to find one??? [Re: John_Kunkel] #1175206
04/01/14 08:43 PM
04/01/14 08:43 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I used a 68 Charger 727 when I built my 70 Satellite. I had everything completed mechanically and working. After paint I started to assemble everything. When I hooked up the back-up lights I checked them with the key on in reverse and they worked. Little did I know they were on in d-2-1 also. So what everyone is saying is that since the 68 trans had a rooster comb for a single NSS when I installed the 3 prong NSS I would have had to change the rooster comb to make everything correct?
...FAFO...
Re: Neutral safety switch--------------Where to find one??? [Re: John_Kunkel] #1175207
04/02/14 03:40 AM
04/02/14 03:40 AM
Louisiana
sparkzz Offline
sparkzz  Offline
Louisiana
Thanks for all the info, guys.
The problem is that I have to jiggle the gear shift while in reverse to find the "sweet" spot that illuminates the BUL's. I've already replaced the NSS twice, so this is about the only thing left. I found out this morning that the part is called a "detent lever" and you can buy a "neutral safety switch detent insulator" kit to replace the insulator. This is about the only thing left, other than a bent or out-of-alignment lever, itself. One other thing that has crossed my mind is maybe the NSS is too long,or installed too tight in the socket. I have temporarily wired a 12v micro-buzzer in the reverse light circuit so I can tell when the BUL's are on. Not really a big thing to me, but the people at the state inspection office would think differently. LOL
Thanks again,
Ken
Re: Neutral safety switch--------------Where to find one??? [Re: sparkzz] #1175208
04/02/14 03:49 PM
04/02/14 03:49 PM
Rio Linda, CA
Rio Linda, CA
Having to jiggle the linkage might be because one of the plastic bushings in the linkage is worn or has fallen out, lay under the car while somebody manipulates the linkage and look for lost motion in the linkage.
Also, it's not uncommon for the shaft in the "detent lever" to come loose and result in lost motion; check for this by disconnecting the linkage from the shift lever and operating the lever by hand...there should be no lost motion between the clicks.
Re: Neutral safety switch--------------Where to find one??? [Re: John_Kunkel] #1175209
04/02/14 07:25 PM
04/02/14 07:25 PM
Louisiana
sparkzz Offline
sparkzz  Offline
Louisiana
Thanks for the tips, I'll check them out when I get under there.
