whats the best engine plate and why? #1175057
02/08/12 09:38 PM
02/08/12 09:38 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
So I need to get an engine plate to install the RB in my 68 dart.Who has the best one and why? How do i figure out how to space out my accessories since it looks like I will be spacing out my water pump with the engine plate?
Re: whats the best engine plate and why? [Re: BEEQUIK] #1175058
02/08/12 11:02 PM
02/08/12 11:02 PM
AndyF Offline
AndyF  Offline
Mancini Racing or Hughes Engines have pre-made motor plates to put a big block into an A body car. They also have pulley spacers and mounting kits.
Re: whats the best engine plate and why? [Re: AndyF] #1175059
02/09/12 01:03 AM
02/09/12 01:03 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
yep, that's a ANDYF plate, best looking one on the market. Just bolt it on set it down on the frame rails . Fab up a couple of plate mounts [ I used 2 x 2 angle ] welded to the frame an your all set to go.
Re: whats the best engine plate and why? [Re: rowin4] #1175060
02/09/12 01:34 AM
02/09/12 01:34 AM
fresno ca
mikeysmopars Offline
fresno ca
Founder and CEO of the Central Valley Mopar Drag Pack
Re: whats the best engine plate and why? [Re: mikeysmopars] #1175061
02/09/12 07:55 PM
02/09/12 07:55 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I bought one from an Indy dealer, but I do not know if it is actually an Indy part. I test fitting it in my '71 Challenger and it fit amazingly, so I am led to believe it is not an Indy made item. The dealer did have RB A-body ones as well.
It just sits on the frame rails and you make some tabs. I should also note, that it is the same thickness as the Milodon gear drive spacers.
Re: whats the best engine plate and why? [Re: BEEQUIK] #1175062
02/09/12 08:21 PM
02/09/12 08:21 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I can build what you need if you want. Feel free to PM me.
-Kenny
Re: whats the best engine plate and why? [Re: BEEQUIK] #1175063
02/09/12 10:16 PM
02/09/12 10:16 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
AndyF's CNCed plate from Mancini here, fit perfect.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: whats the best engine plate and why? [Re: 67HEMI] #1175064
02/09/12 11:32 PM
02/09/12 11:32 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I like the thicker ones it helps control fore aft motion
home of the
Sox and Martin Hemi Duster
