Re: T&D saga [Re: 440lebaron] #1173337
02/16/12 03:56 PM
02/16/12 03:56 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I am glad you are finding things to fix the issues you have. I would continue to scrutinize the entire package. Are your retainers and cups/locaters matched to your springs etc...It's hard to give a comprehensive breakdown of everything you measure/consider when engineering a valvetrain.
Re: T&D saga [Re: HardcoreB] #1173338
02/16/12 04:03 PM
02/16/12 04:03 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
everything else checks out ok, complete valve train is from comp. all there specs.
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: T&D saga [Re: HardcoreB] #1173339
02/16/12 04:03 PM
02/16/12 04:03 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Is there a chance you can take a picture of the broken parts?
Re: T&D saga [Re: Biginchmopar] #1173340
02/16/12 04:11 PM
02/16/12 04:11 PM
westerly, ri. usa
westerly, ri. usa
working on that.....i'm good with a wrench not a keyboard
how do you get **update** to show in the subject?
gary
Re: T&D saga ... UPDATE [Re: 440lebaron] #1173341
02/16/12 08:05 PM
02/16/12 08:05 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
gary
You have to ADD it to the subject of the original post , use the edit button on the first post you made in this thread.
Re: T&D saga ... UPDATE [Re: JohnRR] #1173342
02/16/12 09:05 PM
02/16/12 09:05 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Check for interference everywhere,if you don't find anything look for coil bind.
Re: T&D saga [Re: 440lebaron] #1173343
02/17/12 12:40 AM
02/17/12 12:40 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
ahha, some installed hights are off. some as high as 1.977. that puts springs at 180lbs closed. way to low seat pressure. now i feel better somewhat.
2.037 without spring locator. 2" spring with .030 shim should be just right
gary
seeya
so, of course the question that needs to be asked is......who assembled the heads and didnt check the installed heights?
Re: T&D saga [Re: fast68plymouth] #1173344
02/17/12 02:32 AM
02/17/12 02:32 AM
JohnRR Offline
JohnRR  Offline
gary
seeya
