Page 2 of 3 1 2 3
Re: will it be be absolutely necessary to mill the heads? [Re: JohnRR] #1173177
02/09/12 08:12 PM
02/09/12 08:12 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
No the compression won't damage the gasket . Your compression ratio under 10 is fine as long as you don't run the lowest octane fuel available .
I'm not getting your question , your english is generally good but I'm a little confused by
the flat part of the piston wich leves with the block surface
is that supposed to read
the flat part of the piston which levels with the block surface ... meaning zero deck ?
Yes you´re right, i forgot the "L".
No,i didn,t mean zero deck,I just think that i didn,t have a correct idea about what Quench is..
I was planning to use 95 oct gasoline.Here we have 95 and 98.
98 is more expensive but i,m not going to use the car as a daily driver..
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173178
02/09/12 09:35 PM
02/09/12 09:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hello everybody,
I have a set of new MP 452 heads in the box(84cc chamber)for my 440 engine.
Using a comp calculator i would get a comp ratio of 9.30 with a .039" gasket.
Well, i sent a mail to Hughes for ordering one of their whisplash cams,and they said to me that 9.30 is too low for aluminium heads and i will need to mill the heads 0.50 or 0.60..
Also said that a .020 gasket is not an option for alu heads.
I,m not very happy about that idea...troubles with the intake fitment,valve clearances etc...
What is your opinion?
Thanks a lot in advance for any input.
aren't 452's iron? What'd I miss? Some guys use steel shim gasket w/ alum heads..
Coming soon!!!!
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173179
02/09/12 09:45 PM
02/09/12 09:45 PM
dogdays Offline
dogdays  Offline
These calculations based on 30 over 440, stock stroke, 84 cc head, flat top piston no valve reliefs nearest piston to deck is 0.068".
Mopar machine work wasn't the greatest and I'm betting your decks are not square to each other or parallel to the crankshaft centerline.
A 30 over 440 has about 914cc swept volume. We would like to have 10.5:1 compression with aluminum heads. To find the volume above the piston required for a compression ratio "r", divide by the quantity (r-1). 914 / 9.5 = 96.2cc. The head volume is 84cc so you need just 12.2cc more than the head. A normal 0.040" composition gasket is about 12 cc so you can see you need to delete some volume somewhere. The steel shim head gasket is 5 or 6 cc so let's say 6. Quite a few guys on this board have used them with success.
So your closest piston is 0.068 in the hole which equals 914 * 0.068/3.75 or 16.6 cc. I suggest cutting 0.035" down from the lowest corner so now all the pistons should be 0.033" down in the hole. You now have 914 * 0.033/3.75 or 8cc which plus the 6 cc of the head gasket and the 84cc head gives you 98cc. (914 + 98) / 98 = 10.3:1. I'd live with that. If you think about it you'll see that milling the block is twice as effective as milling a closed chamber head.
If you use just the steel valley pan/intake gasket with a smear of Hylomar around all the openings the intake should bolt on OK. Then all you have to worry about is valve to piston clearance.
Use checking springs with the valves on one cylinder and check the V/P clearance every 5 degrees from 20 BTDC to 20 ATDC and see what you get. One of the cam manufacturers has the procedure posted.
With 0.052" squish clearance your engine will run very well.
Good Luck!
R.
Re: will it be be absolutely necessary to mill the heads? [Re: Mr.Yuck] #1173180
02/09/12 09:53 PM
02/09/12 09:53 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Hello everybody,
If you read up higher you would have seen we discussed this . About 5 yrs ago MP released a new alum head that I am pretty sure is NHRA legal, it's an Ebrock RPM with straight spark plugs and a freeze plug on the end , they call it the 452.
Re: will it be be absolutely necessary to mill the heads? [Re: JohnRR] #1173181
02/09/12 10:43 PM
02/09/12 10:43 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Quench = the area of the combustion chamber where the flat piston and the flat part of the head are. That would be the left side shown here, ignore the huge bump on the piston.
Octane
Your 96 is equivalent to 92 here in the States.
US octane is an average of 2 ratings, research octane (RON) and motor octane (MON). If you look at a gas pump in the United States, you will see a yellow sticker that says "octane by R + M / 2" which is the formula for the average. In Europe, they only report the RON.
Re: will it be be absolutely necessary to mill the heads? [Re: dogdays] #1173182
02/10/12 06:32 PM
02/10/12 06:32 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Good Luck!
R.
Thanks a lot Dogdays for all the work that this text involves.
Those formulas are very interisting and useful.
Couriosly ,is the typical theoricaly part that you find boring until you start to find troubles .
To mill the block sound even worse than mill the heads,however i,m starting to belive that this block could have been milled yet,cause i Googled the pistons part number(L2388) and i found a few posts wich talk about people who have used these pistons on 440 blocks and they sit even deeper than mine,such as 0.080 to 0.12 deck.
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173183
02/15/12 05:48 PM
02/15/12 05:48 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
I have meassured the cylinder height from the top of the piston when it is in it´s lowest position in the hole(BDC) to the block surface and i got 3.858".
3.858"-0.070" deck = 3.788" Stroke?
I was basing my comp calculations on the standard 3.750"...
Am i doing it correctly?
Thank again for your invaluable help
(And I feel sorry for being so bore )
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173184
02/15/12 06:53 PM
02/15/12 06:53 PM
JohnRR Offline
JohnRR  Offline
Are you measuring it on the centerline of the piston over the wrist pin ? That is a lot of stroke increase if it is . Are the rods std. or cut undersize ?
Re: will it be be absolutely necessary to mill the heads? [Re: JohnRR] #1173185
02/16/12 06:25 PM
02/16/12 06:25 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
John,
I,m meassuring from the top of the piston at BDC to the block surface.
Keep in mind that the piston has a very low comp.height.such as 1.926"
How i should to do for meassuring the stroke?
I belive that the rods are the original ones.However tomorrow i,ll try to meassure the distance between the small and big end centers .
Re: will it be be absolutely necessary to mill the heads? [Re: JohnRR] #1173186
02/17/12 09:52 AM
02/17/12 09:52 AM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
I have measured the block height and there are 270mm (10.6299") between the crankshaft center and the block surface.
I have read around here that a 440 block uses to have 10.725" so i suppouse that it has been decked.
Uploaded with ImageShack.us
About the rod lenght i have meassured 180mm(7.086") from the center of the pin to the big end center,or the surface were it meets the bearing cap.
This is what i don,t understand cause the workshop manual says that the are 6.766" to 6.770"???
The rod "I" beam has the number #1851535 stamped on it.
Thanks i advance for any input.
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173187
02/17/12 12:37 PM
02/17/12 12:37 PM
JohnRR Offline
JohnRR  Offline
Seriously ??? A tape measure ?
the part number is a stock factory rod there is no way it is that long , you need to use something a little more PRECISE to measure that stuff.
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173188
02/17/12 02:04 PM
02/17/12 02:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The deck is not exactly the same in all the cyls,but they are between .068" wich is the one most closer to the surface and .074" that would be the most deeper in the hole.
Ok, so if you don't get the same measurement for each piston what does that mean??
a) either the rods are unequal length
b) the piston comp. heights are unequal (not likely)
or
c) the decks are not even (most likely)
I would deck the block to get the decks even and straight and run the gaskets you have with the heads as they are.
People talk about milling the intake surface after milling heads but you rarely see anyone suggesting the same after decking a block! Well, decking a block .010 is no different that milling a head .010! But in your case, you're using a gasket which is .020 thicker than stock so in theory you can knock .020 off the "stock" deck measurement or off the head and you'll still be at stock height.
Re: will it be be absolutely necessary to mill the heads? [Re: JohnRR] #1173189
02/17/12 06:05 PM
02/17/12 06:05 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
The tape is not enough accurate for most things,i know,just something orientative.The trouble is that i can,t to meassure the rod center to center when it is installed .Just to the pin surface to one of the big end corners. This is why there are that big difference.
However knowing that the rods are the stock ones ,doesn,t work to spend more time meassuring them.
Anyway,the piston travel continues being 3.788"(This time using better than a tape tools ,as you can see in the pictures)
What i need to know is what meassure i have to use with the comp.ratio calculator, 3.750 wich is the ratio of one crankshaft turn,or 3.788" wich is the travel from BdC to TDC and it depends on piston comp height.
The CR changes depending on wich of both you are using.
Thanks again
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173190
02/17/12 06:09 PM
02/17/12 06:09 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Off topic for a moment, but I used to have a Bultaco Sherpa T.
Re: will it be be absolutely necessary to mill the heads? [Re: OzHemi] #1173191
02/17/12 07:02 PM
02/17/12 07:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Forget the 3.750. You've measured the piston travel at 3.788 and if that is accurate then that is the measurement you must use.
Re: will it be be absolutely necessary to mill the heads? [Re: Stanton] #1173192
02/17/12 08:46 PM
02/17/12 08:46 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Thanks Stanton,That is what i need to know.
Then the CR would be around 9.6 :1 using a 0.027 gasket
Your impressions about the block deck are right.Someone deck this one in the past, ,0.025 or so.This does not allow to combine a wide range of pistons cause almost all of them are 2.060 CH and they would have an excesive negative deck.
The one and only piston change solution is the 1.991 CH piston,wich would get a zero deck and 10,1:1 CR.
That is why i don,t want to deck the block more than it is.
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173193
02/17/12 10:15 PM
02/17/12 10:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A straight deck is IMPORTANT !! I would not hesitate to deck that block again to get it right - another .010 would not hurt things. Use a thicker head gasket if necessary. You can get as thick as .051 from Felpro.
Re: will it be be absolutely necessary to mill the head [Re: Stanton] #1173194
02/18/12 12:36 AM
02/18/12 12:36 AM
dogdays Offline
dogdays  Offline
The 535 rod is the stock 413/440 rod that is 6.768" C-to-C.
What undersize are your rod bearings?
To increase stroke by offset grinding you have to end up with a smaller rod journal. Unless you are running 0.040" undersize rod bearings I doubt the stroke differs from the standard 3.750.
I think there are a lot of measurement errors that are confusing you.
R.
Re: will it be be absolutely necessary to mill the heads? [Re: Coke] #1173195
02/18/12 10:04 AM
02/18/12 10:04 AM
JohnRR Offline
JohnRR  Offline
Thanks again
Did you check push on the piston to see how much it rocks when you are checking it like it is in this picture .
I haven't gone back and read the thread for your specs but I don't think you have too high a compression ratio to even be worrying about this if you are using alum heads .
What was the question again ?
Looking at the pictures the block has been decked , the .006 difference you are seeing is probably the tolerance stack ups. Do you have a good straight edge or have access to a machinists straight edge , check the block to see if it truely is wavy , I'm guessing it's not that bad.
If Hughes says you need higher compression ratio to use their cam and you want to run the engine the way it is then get a different cam. Contact member fast68plymouth and get a cam from him .
Re: will it be be absolutely necessary to mill the head [Re: dogdays] #1173196
02/18/12 10:07 AM
02/18/12 10:07 AM
JohnRR Offline
JohnRR  Offline
R.
It is possible for the stroke to be off by that much , the crank in my 383 is 3.370 when it should be 3.375, it is cut .010 under so I don't know who shortened it, the factory or ? The plus side is my pistons ended up at zero deck instead of poking out of the block.
Page 2 of 3 1 2 3
