Re: First time on a chassis dyno...
[Re: deaks]
#1172915
02/06/12 02:53 PM
02/06/12 02:53 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Not all dynos are generous, mine made 460, time is in my sig. At what RPM was max power ?. Mick
My 837HP was at 6000rpm
[Re: BB70DUSTER]
#1172916
02/06/12 03:35 PM
02/06/12 03:35 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
The chassis dyno is a great tuning tool as was mentioned previously. I must qualify this by saying it needs to be a "loaded" chassis dyno that can simulate wind resistance and other factors. To me the numbers are meaningless UNLESS being compared to before and after modifications on the same dyno under the same conditions. There are just to many factors/settings that can impact the numbers output by the dyno. It is a tuning tool and nothing more. I say this as an owner/operator of a Mustang Chassis Dyno. It has saved me oodles of time (and money) that would normally have been spent going to the track and testing (actually sitting in the staging lanes mostly). And for reference my car weighs 3700#'s, and on street tires through the mufflers goes 10.5@126 N/A. On my dyno the car makes 439hp to the wheels.
[Re: RobX4406]
#1172918
02/06/12 05:33 PM
02/06/12 05:33 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
You using a plate of fogger?
How much fuel jet size did you pull out of it?
Its a big shot plate... Ended up with 93F 102N @ 6 PSI... still way fat too...
[Re: 1badx]
#1172920
02/09/12 02:37 AM
02/09/12 02:37 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
And for reference my car weighs 3700#'s, and on street tires through the mufflers goes [Email]10.5@126[/Email] N/A. On my dyno the car makes 439hp to the wheels.
At 3550 my car made 398 and went 11.48 @ 120 (no converter or gear but pulled really well)
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: BB70DUSTER]
#1172921
02/09/12 10:36 AM
02/09/12 10:36 AM
Posts: 17,884 S.E. Michigan
ZIPPY
S.E. Michigan
Nice numbers, and sounds like it was a good experience.
I've never had a chassis dyno session....whether with my own stuff or somebody else's, where I didn't enjoy it and where I didn't learn a little something. I think it's well worth doing but obviously not everyone agrees.
Rich H.
Esse Quam Videri
