Page 3 of 5 1 2 3 4 5
Re: 6 spd swap progress [Re: G_T] #1172661
03/06/12 10:54 PM
03/06/12 10:54 PM
Nebraska
72Swinger Offline OP
Nebraska
The engine is out waiting for Milodon so figured while im at it check runout. Isnt exactly easy with only about 2/3s of a circle at best but ordered some RobbMc .014 after I checked it about 15 times.
Mopar to the bone!!!
Re: 6 spd swap progress [Re: G_T] #1172662
03/30/12 01:02 AM
03/30/12 01:02 AM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
i have a viper trans for my gts it.s going behind a R3 race block with efi
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: 6 spd swap progress [Re: sickhemi] #1172663
03/30/12 02:46 AM
03/30/12 02:46 AM
Nebraska
Nebraska
Excellent! That thing outta rip! I'm STILL waiting on Milodon! So whenever that shows I will have a lot more to share.....
Re: 6 spd swap progress [Re: 72Swinger] #1172664
03/30/12 02:48 AM
03/30/12 02:48 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Are you guys going to be running electric speedometers? The T56 doesn't have a mechanical speedo output.
Re: 6 spd swap progress [Re: DaytonaTurbo] #1172665
03/30/12 04:42 AM
03/30/12 04:42 AM
Nebraska
Nebraska
I was originally going to wire a programmable Autometer to my sensor but came across Speedhut having a 15% off sale and ordered one of their GPS speedos instead.
Re: 6 spd swap progress [Re: 72Swinger] #1172666
04/01/12 09:56 AM
04/01/12 09:56 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Getting there..
Is that replacement piece of cross-member considerably thicker than it looks? The original piece of cross-member is quite beefy, about 1-1/2" deep which gives it considerable stiffness. The replacement is just a piece of what appears to be fairly thin metal and in at least one place you have trimmed away the vertical edge (which is short, so already not adding much stiffness to the beam)) for clearance. Hard to tell if you are still running torsion bars or not, which will make a difference. Those torsion bars are trying to twist and the only thing resisting that is the cross-member and if that cross piece is not up to snuff you could get some movement in that cross-member. I am not a chassis designer but I am a naval architect and in multihulls twisting and deflection is something I have to think about and it looks like there could be a problem there.
Looks good overall, just something I noticed.
Oh, with the 2.66 low gear I would keep the 4.10 rear gears, it will be much easier on your clutch. Especially starting on hills you will not have to use as high RPM's etc. Plus you already own the 4.10s.
Best, Dave
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: 6 spd swap progress [Re: David_in_St_Croi] #1172667
04/01/12 04:50 PM
04/01/12 04:50 PM
Nebraska
Nebraska
Yes it is 2"x 1/2" C channel that is plated up to the first bends on both sides and also plated in each bend. I will go get some new pics with it in place from the underside. I also added a stiffener to the trans crossmember before I painted it. I am going to run the 4.10s that are in the car first then decide on 3.91 or not. I also have a 26" tall rear tire so 3.91s shouldnt hurt to bad.
Re: 6 spd swap progress [Re: 72Swinger] #1172668
04/01/12 10:18 PM
04/01/12 10:18 PM
Nebraska
Nebraska
T-bar crossmember. That C-channel is 3/16" thick btw.
Re: 6 spd swap progress [Re: 72Swinger] #1172669
04/01/12 10:20 PM
04/01/12 10:20 PM
Nebraska
Nebraska
And with the trans mount tied into the frame connectors it will probably be stiffer than ever.
Re: 6 spd swap progress [Re: 72Swinger] #1172670
04/02/12 08:22 PM
04/02/12 08:22 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I have a t56 behind a small block with a quick time bell. The quicktime bell is not really machined like a normal bell housing that centers off of the input shaft retainer where you are indexing it off of. Mine was cut real ruff around the circle. I don't really know if that is truely the center. I could not come up witha good way of doing it and ended up just bolting it togeather.
Re: 6 spd swap progress [Re: 72Swinger] #1172671
04/02/12 08:31 PM
04/02/12 08:31 PM
3/16" thick steel oughta do it!
Re: 6 spd swap progress [Re: NoFrills] #1172672
04/02/12 09:37 PM
04/02/12 09:37 PM
Nebraska
Nebraska
Yeah it is not the easiest to dial runout in with. Everything ive read says do it and it is machined with the bore within .005. After I was done I got it from .014 TIR to .005 TIR. With my transmission being brand new I didnt want to chance it.
Re: 6 spd swap progress [Re: 72Swinger] #1172673
04/05/12 12:20 AM
04/05/12 12:20 AM
Nebraska
Nebraska
Havent been able to get alot done 6spd. wise since I had another project tie me up for a while and now finally back on my car. Just recieved my Milodon RR pan after a month wait and started putting it on tonight.
Re: 6 spd swap progress [Re: 72Swinger] #1172674
04/05/12 12:21 AM
04/05/12 12:21 AM
Nebraska
Nebraska
Also recieved my gauges from Speedhut....
Re: 6 spd swap progress [Re: 72Swinger] #1172675
04/05/12 12:22 AM
04/05/12 12:22 AM
Nebraska
Nebraska
And some more goodies...
Re: 6 spd swap progress [Re: 72Swinger] #1172676
04/08/12 01:14 AM
04/08/12 01:14 AM
Nebraska
Nebraska
Got everything mocked up today between pan and K member a steering linkage. Yep its tight.
Re: 6 spd swap progress [Re: 72Swinger] #1172677
04/08/12 01:16 AM
04/08/12 01:16 AM
Nebraska
Nebraska
Pan may get a couple dings when its all said and done.
Re: 6 spd swap progress [Re: 72Swinger] #1172678
04/08/12 01:18 AM
04/08/12 01:18 AM
Nebraska
Nebraska
And with the Schumacher mounts the pan is below the K about a 1/4" so added some Dukes of Hazzard style protection.
Re: 6 spd swap progress [Re: 72Swinger] #1172679
04/08/12 08:51 AM
04/08/12 08:51 AM
NY NY
3
340duster340 Offline
NY NY
looks good, maybe weld a tow point to that spot as well.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: 6 spd swap progress [Re: 340duster340] #1172680
04/08/12 01:38 PM
04/08/12 01:38 PM
Nebraska
Nebraska
Good idea!!
