6 spd swap progress
#1172621
02/05/12 05:07 PM
02/05/12 05:07 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I started this deal a few weeks ago, and I have threads on other sites about it but this site seems to have more interest. 72 Dart with a 451 and about to have a Viper 6spd.
Mopar to the bone!!!
Re: 6 spd swap progress
[Re: 72Swinger]
#1172622
02/05/12 05:11 PM
02/05/12 05:11 PM
72Swinger
Nebraska
Let the butcher get to work!
[Re: 72Swinger]
#1172623
02/05/12 05:13 PM
02/05/12 05:13 PM
72Swinger
Nebraska
Clutch master cylinder im using is a Wilwood 7/8 bore. Here it is mocked up.
[Re: 72Swinger]
#1172625
02/05/12 05:17 PM
02/05/12 05:17 PM
72Swinger
Nebraska
Should work, it bottoms out on the pedal box at the same time the master does. Have since installed pedal stops to dial it in.
[Re: 72Swinger]
#1172628
02/05/12 05:44 PM
02/05/12 05:44 PM
72Swinger
Nebraska
A view of the clearance, trans is 1/4-3/8" higher than it needs to be...
[Re: 72Swinger]
#1172629
02/05/12 05:45 PM
02/05/12 05:45 PM
72Swinger
Nebraska
Passenger side tunnel shot..
[Re: 72Swinger]
#1172631
02/05/12 05:47 PM
02/05/12 05:47 PM
72Swinger
Nebraska
Carpet will work, just regular auto carpet....
[Re: 72Swinger]
#1172633
02/05/12 06:20 PM
02/05/12 06:20 PM
moparpollack
Lil Herman
Lil Herman
85086
So all you had to is change the disc? Or did you have to buy a new flywheel and clutch?
[Re: 72Swinger]
#1172636
02/05/12 11:47 PM
02/05/12 11:47 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
It looks good! Better than mine, which is currently undergoing a similar transformation. Mind has 3.90's right now and I'm considering going to 4.56's with that .5 to 1 sixth gear. Or I might just leave it alone.
Like I said, not as pretty as yours. Yet. Mine also has about 5 inches of set back to it which is why the firewall is cut out like it is. Hopefully I will be able to get into a house with a garage so I can leave the car "in progress" and not have to package it up every time I want to work on it. Makes it hard to work up the enthusiasm to tinker with it.
The reasons for setting the engine back are twofold: one is the rear sump canton road race pan which now clears the center link with ease. Two is just better weight distribution for handling. Ought to make for a fun handling car though. Provided I ever get it done.
[Re: dodgeboy11]
#1172637
02/06/12 12:15 AM
02/06/12 12:15 AM
72Swinger
Nebraska
Right on! Engine set back would nice in mine to. Is that a Camaro trans? That shifter will be right next to your hip pocket lol!
[Re: DaytonaTurbo]
#1172639
02/07/12 04:17 PM
02/07/12 04:17 PM
72Swinger
Nebraska
6spds are mostly used in cars that can take corners. Good luck on your swap. In a couple weeks I'm gonna have more updates. Will have a clutch/flywheel slave cylinder and a new oil pan.
