It should last for normal cruising. I don't like the big lash in spider-side gears that is caused by the cone and case wear. The springs still push the side gears out but that causes the 4 gears to ride higher up on teeth where they become a little weaker for the driver that still intends to put slicks on it and race it. That enhances it's need to explode I believe.
