Re: My new big brakes!
[Re: G_T]
#1172276
04/05/12 01:15 PM
04/05/12 01:15 PM
Posts: 798 WA
pro451bee
WA
Ok Im back , I installed the rear system first and it went well . Every thing fit properly with out any massaging , however the method to center the caliper bracket was either backwards or a misprint on the diagram because it only took half as much shims ,.060 ,as it said, per side ,amazingly even ,to center over rotor .Rear bearings also fit and adjusted properly too.I torqued it all to spec ,bled the air wth new Honda brake fluid and road tested with the factory front brakes still on to isolate the rear upgrade before installing the front 13" system .Dont let any one tell you a rear disk upgrade isn't a worthwhile improvement ,WOW , firmer pedal,less effort and a linear feel to steering under braking! I am very pleased with this brake kit.Will get some more pics of the rear installed system , the Baer rotors look really great as a bonus .
[Re: pro451bee]
#1172277
04/06/12 04:10 PM
04/06/12 04:10 PM
Posts: 798 WA
pro451bee
WA
[Re: pro451bee]
#1172278
04/06/12 04:11 PM
04/06/12 04:11 PM
Posts: 798 WA
pro451bee
WA
[Re: pro451bee]
#1172279
04/06/12 04:12 PM
04/06/12 04:12 PM
Posts: 798 WA
pro451bee
WA
[Re: pro451bee]
#1172283
04/07/12 09:55 AM
04/07/12 09:55 AM
Posts: 801 central CT
cudazappa
central CT
It was asked once, but I didn't see an answer posted. What's your Master Cylinder? Are you running vacuum assist? I spent my tax money on motor trans, so I've favorited this topic for next winter for me ![](/ubbthreads/images/graemlins/3_2_116.gif)
1971 Challenger
[Re: pro451bee]
#1172285
04/07/12 02:33 PM
04/07/12 02:33 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Yuo've got a nice thread going.. thanks for your pics and info! Someday on my T/A I'll upgrade the whole system (use for autocross and hi-speed lapping).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: pro451bee]
#1172287
04/29/12 09:54 PM
04/29/12 09:54 PM
Posts: 798 WA
pro451bee
WA
Got one side mounted on the Bee today .This is the old set up. 38 pounds and 11 inches.
[Re: pro451bee]
#1172289
04/29/12 10:00 PM
04/29/12 10:00 PM
Posts: 798 WA
pro451bee
WA
[Re: 440forPOWER]
#1172291
04/29/12 10:39 PM
04/29/12 10:39 PM
Posts: 798 WA
pro451bee
WA
Rear P.N. is 4142020 Baer Ironsport and front is P.N. 4141006 .Got both sets at Jegs and they did a very cost effective price match also.The spill under the car is only water from rinsing off brake fluid on my new parts.
