Page 2 of 6 1 2 3 4 5 6
Re: My new big brakes! [Re: cudazappa] #1172275
02/06/12 12:44 AM
02/06/12 12:44 AM
WA
P
pro451bee Offline OP
P
WA
tapered bearings in rear ok .
Re: My new big brakes! [Re: G_T] #1172276
04/05/12 12:15 PM
04/05/12 12:15 PM
WA
P
P
WA
Ok Im back , I installed the rear system first and it went well . Every thing fit properly with out any massaging , however the method to center the caliper bracket was either backwards or a misprint on the diagram because it only took half as much shims ,.060 ,as it said, per side ,amazingly even ,to center over rotor .Rear bearings also fit and adjusted properly too.I torqued it all to spec ,bled the air wth new Honda brake fluid and road tested with the factory front brakes still on to isolate the rear upgrade before installing the front 13" system .Dont let any one tell you a rear disk upgrade isn't a worthwhile improvement ,WOW , firmer pedal,less effort and a linear feel to steering under braking! I am very pleased with this brake kit.Will get some more pics of the rear installed system , the Baer rotors look really great as a bonus .
Re: My new big brakes! [Re: pro451bee] #1172277
04/06/12 03:10 PM
04/06/12 03:10 PM
WA
P
P
WA
Installed
Re: My new big brakes! [Re: pro451bee] #1172278
04/06/12 03:11 PM
04/06/12 03:11 PM
WA
P
P
WA
Upclose
Re: My new big brakes! [Re: pro451bee] #1172279
04/06/12 03:12 PM
04/06/12 03:12 PM
WA
P
P
WA
From back more
Re: My new big brakes! [Re: pro451bee] #1172280
04/06/12 03:14 PM
04/06/12 03:14 PM
WA
P
P
WA
Front system almost ready ,Going to paint letters copper first .
Re: My new big brakes! [Re: pro451bee] #1172281
04/06/12 06:17 PM
04/06/12 06:17 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
ProBee:
Those wheels on your Coronet look very nice. They look like the wheels on the green 69 Road Runner from Mopar Action. Great choice!
Re: My new big brakes! [Re: Jjs72D] #1172282
04/07/12 12:30 AM
04/07/12 12:30 AM
WA
P
P
WA
Thanks ,ya I think you are right about the wheels ,Mopar Action Road Runner has the same 17x9 KMC wheels .I thought they look a little like Magnum 500's and they are the right off-set ,"0", for old cars .
Re: My new big brakes! [Re: pro451bee] #1172283
04/07/12 08:55 AM
04/07/12 08:55 AM
central CT
cudazappa Offline
cudazappa  Offline
central CT
It was asked once, but I didn't see an answer posted.
What's your Master Cylinder? Are you running vacuum assist?
I spent my tax money on motor trans, so I've favorited this topic for next winter for me
1971 Challenger
Re: My new big brakes! [Re: cudazappa] #1172284
04/07/12 01:11 PM
04/07/12 01:11 PM
WA
P
P
WA
I am using a AR adapted late model 1.03 alloy master cylinder unit at this time , no booster,on a manual drum brake pedal the car was made with .A Baer tech said to use a 15/16 or 1" master ,so I might need to change it after the front swap but I'm going to try the one mounted on the car now.The pedal effort went down with the rear disk swap and its a fairly small piston caliper at 38mm,or 1.5",so perhaps the large rotors, high friction ceramic pads, braided flex lines and stiff alloy calipers that came from Baer will compensate for the smaller piston size .I'll soon find out and post.
Re: My new big brakes! [Re: pro451bee] #1172285
04/07/12 01:33 PM
04/07/12 01:33 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Yuo've got a nice thread going.. thanks for your pics and info! Someday on my T/A I'll upgrade the whole system (use for autocross and hi-speed lapping).
Re: My new big brakes! [Re: Mopar Mitch] #1172286
04/28/12 11:00 PM
04/28/12 11:00 PM
WA
P
P
WA
Got a new bath scale and personalized my Baer calipers . Going to install the front soon.
Re: My new big brakes! [Re: pro451bee] #1172287
04/29/12 08:54 PM
04/29/12 08:54 PM
WA
P
P
WA
Got one side mounted on the Bee today .This is the old set up. 38 pounds and 11 inches.
Re: My new big brakes! [Re: pro451bee] #1172288
04/29/12 08:59 PM
04/29/12 08:59 PM
WA
P
P
WA
This is the new system ,31.2 pounds and 13 inches.
Re: My new big brakes! [Re: pro451bee] #1172289
04/29/12 09:00 PM
04/29/12 09:00 PM
WA
P
P
WA
Another angle.
Re: My new big brakes! [Re: pro451bee] #1172290
04/29/12 09:09 PM
04/29/12 09:09 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Very nice! What were your part numbers for your kits?
Re: My new big brakes! [Re: 440forPOWER] #1172291
04/29/12 09:39 PM
04/29/12 09:39 PM
WA
P
P
WA
Rear P.N. is 4142020 Baer Ironsport and front is P.N. 4141006 .Got both sets at Jegs and they did a very cost effective price match also.The spill under the car is only water from rinsing off brake fluid on my new parts.
Re: My new big brakes! [Re: pro451bee] #1172292
04/29/12 10:01 PM
04/29/12 10:01 PM
IN
ahy Offline
ahy  Offline
IN
Nice! A couple Q's. What size are the fronts and are the Hubs aluminum?
Re: My new big brakes! [Re: ahy] #1172293
04/29/12 10:10 PM
04/29/12 10:10 PM
WA
P
P
WA
Hubs are alloy and front rotors are 13".
Re: My new big brakes! [Re: pro451bee] #1172294
04/29/12 10:28 PM
04/29/12 10:28 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
