Re: Weird Cam Bolt Washer
[Re: bobs66440]
#1168480
01/30/12 12:54 PM
01/30/12 12:54 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
Ok, I thought it looked wrong. Can I use a standard flat washer? I looked on 440 Source and theirs just looks like a thick flat washer.
NO you need the correct washer , it's THICK for a reason .
[Re: JohnRR]
#1168481
01/30/12 01:13 PM
01/30/12 01:13 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
Right, I meant can I use a thick flat washer like from a hardware store. I looked on Summit site and they only show the bolt. I have to place an order with them anyway so I'll ask if they have any in stock. Thanks.
[Re: bobs66440]
#1168485
01/30/12 02:09 PM
01/30/12 02:09 PM
JohnRR
I don't thing you are not going to get the correct thick HARDENED washer at the hardware store.
I want to say the right washer should overlap the head of that pin some ? I don't remember ???
[Re: bobs66440]
#1168488
01/31/12 06:09 PM
01/31/12 06:09 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The original single-bolt cam washer is a Belleville washer (slightly cup-shaped)...if the replacement isn't a Belleville I would be sure to use red Loctite on the bolt.
[Re: John_Kunkel]
#1168489
01/31/12 06:25 PM
01/31/12 06:25 PM
Posts: 4,799 ILL
MLR426
ILL
Yes I agree with the cupped version but that cupped washer looks dead soft.
logan426
[Re: bobs66440]
#1168490
01/31/12 07:05 PM
01/31/12 07:05 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I've never seen a washer like this. Is it a lock washer of some sort? It was on the engine when I got it.
it looks like somebody lost the correct washer and used some kind of shock washer as a replacement.
[Re: 446acuda]
#1168491
01/31/12 08:11 PM
01/31/12 08:11 PM
bobs66440
That's what it is! I compared it to a shock washer (or maybe sway bar bushing washer) I had in the parts bin and it's identical.
[Re: scratchnfotraction]
#1168493
02/01/12 01:03 PM
02/01/12 01:03 PM
Posts: 13,622 md
mopars4ever
md
makes one wonder what else trick was used in that build?
Fram oil filter?
#1168494
02/01/12 01:15 PM
02/01/12 01:15 PM
Posts: 3,821 New State
kidmopar
New State
Looks like a drilled-out shock absorber washer? I'd sure look a LOT deeper into that one
