Re: My after fire upgrades
[Re: all spooled up]
#1168114
01/30/12 11:44 AM
01/30/12 11:44 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Looks good as always Jimmy.Keep us posted on the progress.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: blown572dart]
#1168115
01/30/12 02:50 PM
01/30/12 02:50 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
That should land you solidly into the mid to low 10's for sure!!!... Local guy here that has a 632 twin turbo 57 Chevy has siumilar issues. Car runs real storng back half numbers, but he has been 3 years trying to work out converters, gears and turbos. Good running, good working car, but never runs a representative ET based on the MPH. Its just tricky hard to get them to ET early in the run. he has a big inch motor too, but is currently downsizing the motor to try a different approach I believe. I wish you could have maximized the screw set up, as there was a lot more in that package, just never got to reach that goal I think. The data recorder will be your friend here.
RIP Monte Smith
[Re: CompWedgeEngines]
#1168116
01/30/12 03:52 PM
01/30/12 03:52 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good luck Jimmy. You will have her flying in no time. Here's a link to a small block single turbo that ran a 3.98 at PRP 2 years ago while I was there. He won the bounty for the first 3 second pass at our door wars class. This is not the pass at PRP. http://www.jensensenginetech.com/
[Re: MIKES_DUSTER]
#1168124
01/30/12 08:51 PM
01/30/12 08:51 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
Either you hit the lotto,sell crack or have a BIG backer!!!!!! How in the WORLD can you afford to build a car 3 times??? Im still trying to build mine one time!!!!!
I work my a$$ off is how and I have been blessed to have some things go my way. I do have some help from vendorswho treat me fairly but for the most part it is out of my pocket.
