Page 3 of 3 1 2 3
Re: 440 .020" Composite Head Gaskets Available? [Re: Jeremiah] #1167762
02/01/12 04:02 PM
02/01/12 04:02 PM
Out in Left Field, NY
bobs66440 Offline OP
Use a .020 Superformance steel shim gasket coated with gold permatex spray. I think they are ~ $25 a set.
<tap> <tap> is this thing on? Call Greg and he will hook you up.
I was told by 440 Source that it has to be a multi-layer gasket, and not to use a steel shim gasket
Re: 440 .020" Composite Head Gaskets Available? [Re: bobs66440] #1167763
02/01/12 04:18 PM
02/01/12 04:18 PM
Production Mopars used steel shim head gaskets, about .020 thick. FelPro composite head gasket is app. .040 thick. If you use the thick gaskets and cut your heads .030, you've only affected the factory geometry .010 - not enough to require milling the intake manifold or the intake surface of the head. So just cut the deck surface of the heads .030, which will give you the extra half point compression you're looking for and you're done.
Re: 440 .020" Composite Head Gaskets Available? #1167764
02/01/12 06:46 PM
02/01/12 06:46 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
Ya Mon mill it...mill it
MOPAR OR NO CAR
Page 3 of 3 1 2 3
