Re: aren't they pretty, winter upgrade.
[Re: pittsburghracer]
#1167331
01/29/12 11:04 AM
01/29/12 11:04 AM
dartman366
Mt. Vernon, Ohio
Bill I have used 3 sets over the years and really like them but do yourself a favor and dummy them on the heads as soon as you can to see if they need some clearancing for the valve springs. Some guys send them back so T&D can do the work or you may lose the warranty if you do it yourself.
Thanks for the heads up, Terry is going to take care of that because the heads need to be cut anyways for tip alignment and height they appear that they will fit but would be too close for comfort so the intent is to use a smaller diameter spring to get a little more clearance, would be going from a 1.625 dia to a 1.550. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Labratt]
#1167333
01/29/12 12:19 PM
01/29/12 12:19 PM
dartman366
Mt. Vernon, Ohio
Bill...way too PERRRTY to hide inside a valve cover!
Yeah,,no kidding,need to be painted the same color as the green on many many dollar bills. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: VernMotor]
#1167337
01/29/12 04:53 PM
01/29/12 04:53 PM
dartman366
Mt. Vernon, Ohio
Well I can you this..It ain't about money if it fix the problem.It was down right crazy at times.and very frustrating..To win a round and not be able to go run the next one.. He got a box of junk parts over this deal ! Never in my life seen a deal like this..You never knew when it was going to break..it might go 6-8 rounds and be OK and then it would break 3 rounds in a row ! valve cover bolts are wore out on that car !
Thanks Rick! You are sooooo right Vern, it was exasperating at times, be going some rounds heading for a good showing and then... poof and a mad dash under the hood to try and fix it, not so bad during time trials where I had some time,,,but getting close to round robin racing... ![](/ubbthreads/images/graemlins/realmad.gif)
[Re: Labratt]
#1167339
01/29/12 11:39 PM
01/29/12 11:39 PM
dartman366
Mt. Vernon, Ohio
Bill..what set-up were you running??
1.6 Erson's,,,they don't make them anymore. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: dartman366]
#1167340
01/30/12 12:07 AM
01/30/12 12:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill.. what head are you using... still the commando... I put the TDs on my W-5s for the Rampage and I cut (if memory is right) .180 off the bases... but the W-5 doesnt have the cradle... just a flat pad.... by the way... love the TD stuff ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1167341
01/30/12 12:38 AM
01/30/12 12:38 AM
dartman366
Mt. Vernon, Ohio
going on the commandos, kinda neat that they sent a gage with the rocker's to measure the stand height and has instruction's on how to do it. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: nhramark]
#1167342
01/30/12 01:00 AM
01/30/12 01:00 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I have Jesel rockers on my 540. I never (ever) worry about valvetrain failure anymore. You will love the peace of mind that setup will give you.
I broke a T&D intake yesterday.. ![](/ubbthreads/images/graemlins/down.gif)
Chris.. ![](/ubbthreads/images/graemlins/apimp.gif)
[Re: dartman366]
#1167344
01/30/12 01:07 AM
01/30/12 01:07 AM
Chris'sBarracuda
Arizona
Chris..
when did they make them in blue? looks like a mopar performance rocker from here.
T&D's all used to be blue, but now they look like Jesels..
My Exhausts are like that..
Chris.. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dartman366]
#1167345
01/30/12 01:08 AM
01/30/12 01:08 AM
MR_P_BODY
Chris..
... I dont see where the bearing was ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1167346
01/30/12 01:19 AM
01/30/12 01:19 AM
Chris'sBarracuda
Arizona
Chris..
Look closer.. Intake #5.. ![](/ubbthreads/images/graemlins/biggrin.gif)
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Chris'sBarracuda]
#1167349
01/30/12 03:25 AM
01/30/12 03:25 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Chris, That looks like a Mopar rocker not a T&D. The T&D's have needle bearings on the shaft mount rockers and the paired shaft ride on a 5/8" shaft with bearings as well. If you are running over 600# of spring pressure you should have the paired shaft rockers. Just to make sure you should call T&D and ask for Sheldon he can tell you exactly what they are and when they were built just so you know. 1(775)884-2292 ![](/ubbthreads/images/graemlins/beer.gif)
