14-71 in a 67 b-body
#1167171
01/28/12 01:21 PM
01/28/12 01:21 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I talked to Andy at Littlefield a couple a days ago and he suggested running a 14-71 at 10 under on the Hemi. Said it should make 10-13 psi at 10 under and have cool intake temps compared to an 8-71 at the same boost. Question is will a 14-71 clear the firewall in a 67 with an Indy 10 bolt blower intake?
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
Re: 14-71 in a 67 b-body
[Re: 67HEMI]
#1167177
01/29/12 03:14 PM
01/29/12 03:14 PM
67HEMI
Looking at this link a 14-71 is 4 inches longer than a 6-71,all to the rear I would assume. This is a very good link with a lot of good basic blower info. I wish I could find more than one person who has ever run the Hampton Super II 8-71. It is pricey but Don Hampton says it makes 526 cfm per revolution verses 514 for a standard 14-71.Here is the Holley/Weiand link. http://www.holley.com/data/TechService/Technical/Supercharger%20Tech%20Info.pdf
[Re: 23T Hemmee]
#1167188
02/04/12 02:38 AM
02/04/12 02:38 AM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
My Mooneyham 14 is actually a couple of inches ahead of the bellhousing with a standard Veney manifold with a 5-inch drive snout.
Was out of town when I wrote that, after measuring, it's only 3/4" ahead of the bell housing face, but the right side valve cover is actually 1 1/2" behind the bell face. The distance from the last blower stud to the last intake bolt on the right side is about 6 1/2". Keep in mind this is on a Veney fuel 10-bolt head, but I measured a KB manifold against a Brad 10-bolt head and it was the same measurement. I don't know if that will help or make it more confusing, if so, just disregard.....
[Re: mopar_mark]
#1167190
02/04/12 05:06 PM
02/04/12 05:06 PM
67HEMI
Thanks 23T and Mark. Very good info. With my wiper motor looks like a 14-71 is out of the question.
