Re: anyone running cracked magnum heads?
[Re: racerx]
#1166012
01/27/12 06:22 PM
01/27/12 06:22 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
A 95 is OBD-1, and check engine usually means a a malfunction with an emissions item. OBD-2 can set a light for a cylinder misfire, but it would take 1 big crack to leak enough compression to cause a misfire.
Yes, Hughes makes an improved casting that also has press-in seats (OEM is induction hardening of the cast-in seat).
EngineQuest also has the same head, there are a few places on Ebay that sell the cheaper replacements (meaning, all stock valves, springs, etc). Look for 'Clearwater', IIRC.
[Re: Fury Fan]
#1166013
01/28/12 05:38 PM
01/28/12 05:38 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
I currently have three 5.9L Magnum engine powered Dodge Ram 2wd Trucks (a 1999 1500 with 255k, a 2001 1500 with 160k, and a 2001 2500 with 175k). Likely all of them have cracked heads and all three trucks run fantastic. No loss of power, no smoke, no coolant loss. I also run a carbureted 5.9L Magnum engine in a Duster and it too has the original heads (engine was from 2000 Dodge Ram Van 2500 with 130k). I do have a pair of Mopar Performance R/T iron heads, and Mopar Performance Magnum aluminum heads that will eventually make their way on to a couple of the above vehicles.I bought the MP heads years ago, so that may actually never happen.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
[Re: 1980volare]
#1166015
01/28/12 09:00 PM
01/28/12 09:00 PM
Posts: 4,076 Mo.
racerx
Mo.
mine had 1 crack, my machine shop pressure tested the head and it was fine. no loss of coolant, and no burning of coolant. id imagine 75% of magnum heads are cracked somewhere. if it hold pressure, use em.
I'm u say that one head has a crack,then it was presure tested with no cracks so were was the crack?
[Re: d-150]
#1166017
01/28/12 09:13 PM
01/28/12 09:13 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
They do crack between the valves but the crack seems to dead head into nothing and not leak. The cracks usually (almost always) show up on a magnaflux or zy-glo test but almost always pass a pressure test(actually never seen one fail). That shows they are there but doing no harm.
[Re: 1980volare]
#1166018
01/28/12 10:49 PM
01/28/12 10:49 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
has a crack, between the valves. doesnt leak any coolant. doesnt effect performance in any way. most heads that are cracked are easily visible with the naked eye after a good cleaning. if there cracked, get them pressure tested, and if they check out run em.
[Re: 1980volare]
#1166019
01/28/12 11:13 PM
01/28/12 11:13 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
anyone running cracked magnum heads? To the O/P, almost everyone running a truck with a 5.9 V8 has cracked heads that don't hurt anything (whether they know it or not). Not usually a fatal flaw. If there is no white smoke or coolant loss, there is no problem.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Rug_Trucker]
#1166024
01/29/12 09:53 PM
01/29/12 09:53 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
The cracks tend to be very small, sometimes impossible to see when you know where one is located. Even if not filled in with carbon (unlikely) the effect on leak-down would be close to zero, much less than ring end gaps.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1166025
01/30/12 11:39 AM
01/30/12 11:39 AM
Posts: 4,799 ILL
MLR426
ILL
I agree somewhat with what your saying but over time the exhaust valve side of the crack will burn the valve face and show up as a mis-fire. It's just a matter of time. And yes magnum heads are famous for this cracking problem, it is a thick part of the casting between the seats and it will in time cause problems with valve sealing.
logan426
[Re: MLR426]
#1166026
01/31/12 11:21 AM
01/31/12 11:21 AM
Posts: 4,076 Mo.
racerx
Mo.
Seems like a few guy on have these heads on there car/trucks that runs very well anyone ever thought or tried any of this stuff http://www.autozone.com/autozone/accesso...omString=search seems everyone has very little to none leakage wondering if this stuff works or is it just a bandage?
[Re: racerx]
#1166027
01/31/12 12:51 PM
01/31/12 12:51 PM
HotRodDave
Kalispell Mt.
I have never seen a cracked head cause a problem on a magnum motor and I have worked on tons of them. As for the head gasket/crack aditive you should definately NOT use it. I have seen it plug heater cores and radiators.
[Re: racerx]
#1166028
01/31/12 03:47 PM
01/31/12 03:47 PM
1980volare
Dayton, OH
temporary solution to a permenate problem
