Re: Socket size for 1972 B body ball joint at UCA [Re: wvmarv] #1165982
01/29/12 01:53 PM
01/29/12 01:53 PM
California
moparbroz Offline OP
California
Thanks much!
I used to have one that had both sizes in one socket, think it was SK but can't remember now. That was back when I was a Mechanic for a living. Must have changed a hundred ball joints with it atleast. Best way is to loosen the ball joint from the spindle, leave bj shaft in spindle with the castle nut on it a few threads to hold it. Then break the ball joint loose from the upper control arm with a breaker bar and a cheater pipe. Once broken loose finish taking it out with an impact gun. Be careful when re installing in the upper control arm to no not cross thread the new ball joint. Screw the new ball joint down as tight as you can get it with the impact gun, then make sure its tight with breaker bar and cheater pipe. Put shaft back in spindle, tighten castle nut, install cotter pin. Piece of cake.
Hebrews 11:1
Re: Socket size for 1972 B body ball joint at UCA [Re: SCVpolara] #1165983
01/29/12 01:59 PM
01/29/12 01:59 PM
California
California
I am in the city of Orange. Where are you?
Where in CA are you? I could let you bowwor it just leave a deposit
Hebrews 11:1
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165984
01/29/12 02:40 PM
01/29/12 02:40 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Also make sure your car is well supported by jack stands and maybe leaving the jack under it as well. The amount of leverage you sometimes have to put on a cheater bar to get them loose can move the car. Almost had one fall off when I was leaning on it hard. You can also have someone lean the other way on the car to counteract it.
