Page 2 of 3 1 2 3
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: ScottSmith_Harms] #1164938
02/03/12 01:41 AM
02/03/12 01:41 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is a set on factory 1967 14 x 5.5 rims, these rims only came on HP cars and B-body wagons in 66/67, all others had the slightly narrower 14 x 5.0 rims but used the same hub caps (or full wheel covers if so optioned).
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: roadrunninMark] #1164939
02/03/12 01:45 AM
02/03/12 01:45 AM
waco tx
gogo318 Offline
gogo318  Offline
waco tx
those fit 14 and 15 those in the pic appere to be post 70s (and probably even earlier) and will fit wheels from 68 to 84 i know this cause my van and my newport swap out caps perfectly what i wanna know is dose any one close to (or even better in) texas have a pair of widened wheels in 15s like those a lil further up wanna do some trading for 14s with the 67 factory charger hubcaps ? or cash is good too!
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? #1164940
02/07/12 03:48 PM
02/07/12 03:48 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Has anyone made a set of the older large diameter hubcaps (pre 67)fit on newer more common steel wheels? If so how? I thought of using some newer damaged dog dishes and epoxying them to the older hubcaps. Any ideas?
That's exactly what I did.
PC7 epoxy and put the little 9" cap inside the 10" cap so I could run 8" Wheel Vintiqes steelies on the back of my '63.
Is the fit between the two hubcaps snug or do you need to do a lot of filling with the epoxy?
How do you mount and unmount the doubled up caps without breaking the epoxy bond?
Do you have any pics of the hubcap setup from the backside?
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164941
02/08/12 05:14 PM
02/08/12 05:14 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Bump, I would like to know more about this technique also.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rapom] #1164942
02/08/12 09:08 PM
02/08/12 09:08 PM
Simple, really.
Just smear some right in the middle of the cap and carefully line up the one that sits in it to where you have an equal amount of space around the outer edge.
That PC-7 is amazing stuff and bonds like crazy!
I've had them off and on a couple of wheels and no problems yet.
Here is a pic:
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rapom] #1164943
02/09/12 12:54 AM
02/09/12 12:54 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
You could weld on the tabs on the newer rim to make them bigger so that the older cap will catch.
That's what I'm going to try to do.
If you are looking for the older style rim in a 15" size, good luck. Took me a long time to find mine.
You can find them on 60-66 dodge half ton pickups, Mid 60's studabackers, and on some 66-67 C-bodys
And they won't work with disc brakes.
I sell these ones & they DO fit fine with factory discs. I fitted one of these wheels on a '68 GTX w/factory discs several years ago. No clearance issues.
http://www.classicchambered.com/rims/a15.jpg
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? #1164944
02/09/12 02:32 PM
02/09/12 02:32 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Simple, really.
Here is a pic:
Thanks for the information and the picture. Not being the sharpest knife in the drawer though, I can't figure how you pry the caps off of the wheels without breaking the bond between the inner and outer cap?
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164945
02/09/12 02:45 PM
02/09/12 02:45 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
As long as the expoxy is stronger than the force needed to get the caps off the wheel it shouldn't be a problem.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: Sunroofcuda] #1164946
02/09/12 04:20 PM
02/09/12 04:20 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have a set of the mid 60's 15" big cap wheels and they won't fit the a-body disc brakes on my 65 coronet without a spacer.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: lewtot184] #1164947
02/09/12 07:03 PM
02/09/12 07:03 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I need to try that on my '64 wagon as I want to put the dog dish caps back on it and I have the A-body style discs up front. I've got some early A100 15" wheels.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: 1_WILD_RT] #1164948
02/10/12 09:01 PM
02/10/12 09:01 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Another approach that might work well is to use spring clips like allot of earlier cars used... They are available for VW's & would probably work well for this too, just a little effort figuring out where to position the clips..
http://www.mamotorworkstv.com/vw/product/retaining-clip-rivet-set-hubcap-for-1-wheel_375591/
I looked at some pictures of VW wheels and these clips. The VW hubcaps actually fit into a depression in the wheel. They are located by this depression. The clips just keep the hubcap from flying out of the depression. I doubt that they would function on Mopar wheels as the cap just sits "on" not "in" the wheel.
Seems that the idea of welding short pieces of 1/2 X 1/2 angle to the wheels is the best idea (in my opinion) so far. That should make the mount 1" larger in diameter.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164949
02/11/12 09:58 AM
02/11/12 09:58 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have a set of the 15x5 1/2" big cap wheels and looked around at having them widened. i thought it was cost prohibitive and didn't care for the way the work would be done. so, i played with some different ideas, including a spring steel clip, and the angle brackets was the easiest and most secure way to attach the cap. if you can do some welding the cost is very low.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: lewtot184] #1164950
02/11/12 12:54 PM
02/11/12 12:54 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Lewto184, I think that you are right on. I checked on having some wheels widened and came to the same conclusion. Just ordered a pair of 15X6 4"BS and a pair of 15X10 4 3/4" BS from Speciality Wheel. They have to be made of course, taking a couple of weeks, and I still have to adapt the early hubcaps as they are made with the later centers. I ordered them in raw steel so not only are they cheaper, but ready to weld on. After indicating them to check for runout and trueness, I'll do exactly what you did before I paint them.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: NicksGarage] #1164951
02/12/12 06:17 PM
02/12/12 06:17 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Just tried one of the A100 15" wheels I have on my '64 wagon and it does hit the caliper. The shape of the hoop is the problem. I guess I won't be putting the dog dish caps back on my car anytime soon.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: gregsrt] #1164952
02/28/12 12:55 PM
02/28/12 12:55 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I received my new wheels from Specialty Wheels. Outstanding and they are American made. They only have the centers for the later 9" hubcaps available. Lewto184 had a great idea on welding some spacers. After taking a very close look at original wheels however, you'll find that the "nubs" are slightly indented at the bottom. Reasoning that the older hubcaps are exactly 1" larger than the newer ones, it made sense to add 1/2" to each nub but have them undercut in order to capture the hubcap. I cut some spacers, 5/8" long from a few old 1/2" bolts and tacked them to one wheel. Perfect. The hubcap fit like factory. Did all four wheels and finish welded them. The roundness of the 1/2" stock holds the cap perfectly tight to the wheel. Attached is a picture after welding and priming.
This is the land of the free because of the brave
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164953
02/28/12 01:04 PM
02/28/12 01:04 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164954
02/28/12 01:13 PM
02/28/12 01:13 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Another
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164955
02/28/12 01:38 PM
02/28/12 01:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Very Cool!! Those 10's or 12's?
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164956
02/28/12 02:59 PM
02/28/12 02:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
looking good! i'm going to try and find me a set of 15x6.5's and do a set for my 65 coronet.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: 1_WILD_RT] #1164957
02/28/12 03:08 PM
02/28/12 03:08 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Fronts are 15X5.5 Rears are 15X10. I'm anxious to get the prostars off of my '65 Coronet and get these on. Probably another week or so to get them painted, cleared, and the tires mounted and balanced. Still have to wax the hubcaps after polishing them out, too. Hope that the Coronet will have more of a nostalgic look.
Page 2 of 3 1 2 3
