Parking cable moves the parking paw there is a procedure on removal and installation. to remove you remove the allen plug on the housing (there will be some fluid here) undo the nut that is where the cable enters the housing and tap the shaft in to release the cable. Use a small screwdriver and lightly push up on locking spring and pull cable out. To install reverse procedure but make sure cable end locks into the shaft.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
