Re: What does "Machine for Hemi Oiling System" mean?
[Re: Meangreen68]
#1162989
01/22/12 08:59 PM
01/22/12 08:59 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
Drilled for 1/2" oil pick up.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
[Re: Meangreen68]
#1162991
01/22/12 09:16 PM
01/22/12 09:16 PM
Posts: 44,019 Bend,OR USA
Cab_Burge
Is the block machined for the 1/2 NPT size?
[Re: Meangreen68]
#1162992
01/22/12 09:16 PM
01/22/12 09:16 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Do you have the block close by? Tree'd by Cab... Mike may have opened the main passages but left the pick up boss @ 3/8" NPT. I had him open mine up to 1/2" NPT. Then the Milodon pick up I got through Mancini had 1/2" rod threads (no tapering). I had to order in die cause no one local stocked it. It came in handy when it was time to "clock" the pick up tube.
[Re: Meangreen68]
#1162997
01/23/12 01:45 AM
01/23/12 01:45 AM
64Post
Baltimore/Denver
Thanks Dayclona,
It is definitely not machined for a 1/2" pick-up.
I do notice, when looking through the pump-side bores, the turns look like they've been radiused. Fresh burr markings.
I'll know more when the engine is taken out of the plastic wrapping and placed up on a stand.
It looks like Mike clearanced for the 3.9" offset-ground crank/rods on the edge next to the pick-up bore.
Maybe the 1/2" pick-up wouldn't have worked/fit?
So Mike likely opened the feed holes to the mains only. Like I said, I had him open my pick up boss to 1/2" NPT on my low deck. I used chevy rods and a 3.9 crank in my build as well and didn't need the boss clearanced.
Be very careful when installing and clocking the pick up tube. Trying get that last 90 degrees could crack the boss.
[Re: 64Post]
#1162998
01/23/12 10:13 AM
01/23/12 10:13 AM
RapidRobert
they charged you for "machined for hemi oiling system" but the block was not drilled/tapped for the Hemi 1/2" pickup???. What DID they charge you for? They may have done other block oil passage mods (recommended) but the 1/2" pickup is part of the procedure. We're missing some info here
