Rust Question #116287
09/06/08 11:33 PM
09/06/08 11:33 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
For small surface rust repair what's the best method? My Dart has small spots from rock chips over the years. I don't want to cut a solid rocker out for a small amount of surface rust. Yet I am scared it will come back thru the new paint. What's the best method grinding it out and then acid etch primer and metal glaze over the acid etch primer???
Re: Rust Question [Re: moparpollack] #116288
09/07/08 12:15 AM
09/07/08 12:15 AM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
I'd Grind it as clean as I can then treat it with a phosphoric acid based metal prep (PPG DX520, Ospho, Pickelex etc.) scrubbing with a scotch brite pad, wipe it off, when dry apply 2 coats of a good epoxy primer.
It works.
Re: Rust Question [Re: Kingy] #116289
09/07/08 12:19 AM
09/07/08 12:19 AM
85086
Lil Herman
Lil Herman
85086
Great looks like another trip to the paint store. I think they have a $35 minimum charge.
Re: Rust Question [Re: moparpollack] #116290
09/07/08 12:27 AM
09/07/08 12:27 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Just go to your local hardware store & get some Metal Etch, it will be near the paint...After grinding/sanding away as much as is reasonable I spray the area with Metal Etch & scrub it throughly with a Scotchbrite then I prefer to wipe it down with a few rags soaked with laquear thinner... After that prime & do your normal prep..
Re: Rust Question [Re: 1_WILD_RT] #116291
09/07/08 12:35 PM
09/07/08 12:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You can use a small dremel cutting bit to dig rust of of small pits the same way a dentist digs out a cavity. If you have a lot of surface area to cover get a small spot blasting gun from eastwood.
When you wipe metal prep over rust it turns darker than the surrounding metal. Keep going until the dark spots are gone.
