Oil mods
#1162696
01/22/12 04:43 PM
01/22/12 04:43 PM
Posts: 108 so ca
mikesiron
so ca
Thought I would share things I have learned over the years of circle track racing.Let me see if I can post some pic. These are some of the things you will need in the pic. Some of this may be a little difficult but the info is still worth sharing. All of these mods can be found on Mopar Chat in the circle track section. There is not a lot of pic left because the post is so old,so i will post and explane as best i can.
Re: Oil mods
[Re: mikesiron]
#1162699
01/22/12 05:23 PM
01/22/12 05:23 PM
Posts: 108 so ca
mikesiron
so ca
Now remember when I refur to the rt side of the block im talking about the pass side. From the top of the block remove the oil sending unit and drive out the frezee plug that is inbetween the two oil galleys. I use a 5/16 alltread for this. Now make sure this passage is 1/2 if not drill it from the rear main to the main oil galley that feeds the rt lifters.You only need to go as far as the oil galley that feeds the rt side lifters that is the main oil galley. Some blocks do not have a frezee plug inbetween the two oil galleys before you try to remove it with the 5/16 alltread look to see if there is a freeze plug in there.I dont know how they do it but if its cast iron in there its already 1/2 on the other side. Dont forget to put the plug back in when you put the engine back together!!
Re: Oil mods
[Re: mikesiron]
#1162705
02/05/12 05:16 AM
02/05/12 05:16 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Now you can see the tube that I use to oil the left lifter galley. If you want to oil the Left side this way you must block the oil that comes up from the #1main. Just put 2 frezee plugs in the left front oil galley covering the oil hole from the #1 main bearing. The tube itself is a 3/16 brake line with a compression fitting. Tapped into the oil galley with 1/8npt.
Why "must" you block the oil from the #1 main up to the left galley? Oil pressure should be equal all throughout the system and leaving that open should not adversely affect oiling to anything. Not trying to be critical, just thinking that step isn't necessary. Please correct me if I'm wrong.
Re: Oil mods
[Re: mikesiron]
#1162707
02/05/12 11:21 PM
02/05/12 11:21 PM
dodgeboy11
Las Vegas, NV
What we are trying to do is keep as much oil to the crank as possible. The stock oiling to the left lifter galley is feed from the #1 main. By blocking it off and feeding it with the crossover tube the #1 main will live longer.
Yes, I understand this, but with the crossover tube to the left side galley, the oil won't necessarily be traveling up from the #1 main to the left galley because there's already equal pressurized oil coming down from the galley. I'm just arguing semantics because with the crossover tube, I don't see how it matters if you block off the left side oil galley from the #1 main. It would almost be like it was getting oiled from both left and right side oil galleys.
Re: Oil mods
[Re: mikesiron]
#1162713
02/07/12 01:18 AM
02/07/12 01:18 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Is it possible to run an oil cooler on your track car? If so, what are you using? Oil doesn't like 300*
