Re: Tore into the engine tonight....**UPDATE**
[Re: pittsburghracer]
#1162336
01/26/12 11:53 PM
01/26/12 11:53 PM
Posts: 3,456 Out West
408strokerdart
Out West
Sorry to hear that Brian. I hope you caught it before it did major damage.
Will know more when I get the engine out and on the stand where I can tear the rest down.
[Re: 408strokerdart]
#1162337
01/27/12 12:00 AM
01/27/12 12:00 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Sorry to hear about the damage. We have issues as well. I'm about to the point of selling it all. ![](/ubbthreads/images/graemlins/rant.gif)
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#1162339
01/27/12 12:22 AM
01/27/12 12:22 AM
408strokerdart
Out West
We must be on the same page....it crossed my mind.
#1162342
01/27/12 01:22 AM
01/27/12 01:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The culprit of the loose valves was destroyed lifters. One completely gone roller....found three pieces of it, no shaft and only five needle bearings up top. Number 1 cylinder is scored and I need to see how bad it is. I am dreading having to re-bore this and buy new pistons for an engine with so few passes.
I think I have a bad lifter on my W-2 engine... I havent looked yet to see what the problem is... that'll wait till I get that engine on the stand... I'll put the W-9 back in ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1162343
01/27/12 02:05 AM
01/27/12 02:05 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
That sucks but now you know the importance of checking valve lash after every pass. if its loose its a pushrod or lifter or rocker, if its tight the valve is pulling through.
Don't get depressed if it was easy to go fast everybody would be!
BB, TT5,Procharged 3300lb Street Car 4.79/154
#1162344
01/27/12 03:59 AM
01/27/12 03:59 AM
Posts: 19,386 Las Vegas
Al_Alguire
Las Vegas
Brian sorry to hear about the problem. Hopefully you caught it before any of those little needles did any real damage to things. I am pretty religous about lash. Even once it is stable we still chack it at every race. That does not guarantee no problems but we rarely let it go more than 10 passes without checking it out.
Believe me I feel your pain. Checking mine at a race after it was not running the number it should, and we are talking a few thou off is how we found the bad LSM cam. Cam apparently lost its heat treat and was peeling material off, found it by lash on two cylinders being off. Caught it before it did much damage but I always check it over if it falls off for any reason.
[Re: Al_Alguire]
#1162345
01/27/12 07:47 AM
01/27/12 07:47 AM
Posts: 6,150 Melbourne , Australia
LA360
Sorry to hear of the damage Brian! Hope it's nothing too serious! What lifters are you thinking about dropping into there to replace these ones? You were running Crane Ultra Pro's?
Alan Jones
[Re: LA360]
#1162347
01/27/12 10:10 AM
01/27/12 10:10 AM
408strokerdart
Out West
They were Crane Ultra Pro's. Don't know what I will use next. Possibly Morel since they have a direct replacement for the Crane with the offset that I need. The offset narrows down my selection and I know the oil holes in the bushings work with the crane (pushrod oiled).
As far as serious, probably nothing $3-$4K won't fix. ![](/ubbthreads/images/graemlins/rant.gif)
[Re: Al_Alguire]
#1162348
01/27/12 10:13 AM
01/27/12 10:13 AM
408strokerdart
Out West
Strange thing Al is that it ran the quickest/fastest it ever has on the last pass. I just can't believe that nothing could be heard. But, yes I did fall off of my normal maintenance routine. That won't happen again.
#1162349
01/27/12 01:00 PM
01/27/12 01:00 PM
Al_Alguire
Las Vegas
FWIW I have been running Isky EZ Rolls and have had zero isues with the lifters. Plus no needle bearings ![](/ubbthreads/images/graemlins/biggrin.gif) The fact that it picked up might say something about the engine combo and camshaft selection ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Less lift and less duration and you went faster. Then again the few engines I have had that went BOOM, usually ran thier best the previous pass ![](/ubbthreads/images/graemlins/runaway.gif)
#1162353
02/23/12 10:12 AM
02/23/12 10:12 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Highly disappointed in the findings from tearing down this engine. Seems there are problems at every turn so far.
The heads are at a professional shop to get checked out. If you are reading this and missed the first part, the easy thing to check for me was the valve springs were set up with a installed height that was over .200" from coil bind. Further inspection is finding the following: wrong length valves for the heads, tips of intake valves beat up, intake valves with less than acceptable margin, valve guides with up to .007" clearance, several exhaust valves not even sealing to the seats, etc..
Remember this engine has only about 60 passes on it. I don't think it would have stayed together much longer (in the valvetrain) and it seems that it is a good thing that the improper spring set-up caused the lifter failure or I might have run this until a catastrophic failure occured. These problems didn't just happen in 60 passes....they were there from the start.
It will be put together right this time and should finally run to it's potential.
Wow.....
Lucky that thing didn't really hurt itself.
