Re: Ladder bar bending the diagonal link. UPDATE
[Re: smokinwoody]
#1160802
02/13/12 12:36 PM
02/13/12 12:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Cab...thats an iddy biddy diagonal you have there..
I know there isnt suppose to be that much side load unless you are taking corners pretty hard or something smacked it hard from above like bottoming out a suspension and having the driveshaft hit it..
I would install a beefier one like suggested....
The drive shaft sould be moving the same amount as the dia link so it shouldnt hit... unless he took the shocks off and let the diff hang way down... thats a cornering or a hit that bent it (tooo wimpy)
[Re: Cab_Burge]
#1160804
02/14/12 03:12 AM
02/14/12 03:12 AM
Posts: 3,505 DFW
mr_340
DFW
http://en.wikipedia.org/wiki/BucklingRead up on compressive buckling and slenderness ratio (length to diameter). Think of a pushrod, they fail in the same manner. Go to a bigger diameter (increases the area moment of inertia, I). Changing to 4130 from mild steel won't help since the modulus of elasticity is about the same.
Floyd Lippencott IV
