Re: Ladder bar bending the diagonal link. UPDATE [Re: 9 Sec Phill] #1160798
02/13/12 01:57 AM
02/13/12 01:57 AM
Cab_Burge Offline OP
3rd attempt to attach that picture
Re: Ladder bar bending the diagonal link. UPDATE [Re: Cab_Burge] #1160799
02/13/12 06:07 AM
02/13/12 06:07 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Could you have hit a pot hole or do you need some curb scrapers cab?
Re: Ladder bar bending the diagonal link. UPDATE [Re: Cab_Burge] #1160800
02/13/12 11:29 AM
02/13/12 11:29 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Post hijack alert!!! Cab, What micron screen is in your pre-pump filter? Also, how much higher is your fuel pump than the sump? I'm just seening some potential fuel delivery issues and trying to be constructive, not pointing out any flaws.
Re: Ladder bar bending the diagonal link. UPDATE [Re: Cab_Burge] #1160801
02/13/12 12:22 PM
02/13/12 12:22 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Cab...thats an iddy biddy diagonal you have there..
I know there isnt suppose to be that much side load unless you are taking corners pretty hard or something smacked it hard from above like bottoming out a suspension and having the driveshaft hit it..
I would install a beefier one like suggested....
Re: Ladder bar bending the diagonal link. UPDATE [Re: smokinwoody] #1160802
02/13/12 12:36 PM
02/13/12 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The drive shaft sould be moving the same amount as
the dia link so it shouldnt hit... unless he took
the shocks off and let the diff hang way down...
thats a cornering or a hit that bent it (tooo wimpy)
Re: Ladder bar bending the diagonal link. UPDATE [Re: HardcoreB] #1160803
02/13/12 02:33 PM
02/13/12 02:33 PM
The pump entrance is lower than the sump outlet. That is a Aeromtive screen filter, 100 Microns if my memory is serving me correctly I did have a BG 500 filter on it before with there 10 micron paper element filter on it before and it did affect the pump That was my fault Once that was corrected I found that the motor needed .120 needles and seats to be able to jet the carbs. up enough the fatten the AFR enough to slow the car down in the 1/4 MPH It never ends
Re: Ladder bar bending the diagonal link. UPDATE [Re: Cab_Burge] #1160804
02/14/12 03:12 AM
02/14/12 03:12 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
http://en.wikipedia.org/wiki/Buckling
Read up on compressive buckling and slenderness ratio (length to diameter). Think of a pushrod, they fail in the same manner. Go to a bigger diameter (increases the area moment of inertia, I). Changing to 4130 from mild steel won't help since the modulus of elasticity is about the same.
Floyd Lippencott IV
