2001 Ram 2500 Heater Core Replacement #1158793
01/16/12 06:28 PM
01/16/12 06:28 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
My heater does not work and I changed the thermostat(195) last Saturday and it made no difference. I have been told that my heater core needs replacing. How hard is it to change?
Re: 2001 Ram 2500 Heater Core Replacement [Re: 68GTS383] #1158794
01/16/12 06:31 PM
01/16/12 06:31 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
My 96 2500 needs one and the cheapest price I got was $600-700 and most shops here will not even do it...The front seat should come out then the whole dash needs to come out then the heater box can be removed...With a bad back it's way too much for me to do...
Re: 2001 Ram 2500 Heater Core Replacement [Re: QuickBpBp] #1158795
01/16/12 06:51 PM
01/16/12 06:51 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I may guess that most shops won't touch it because of liability. The brittle plastic dash tops and bezels will fall apart if you look at them wrong. They don't want to buy you a new dash.
Try back flushing the core before you tear into it to see if you can knock any sludge loose.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 2001 Ram 2500 Heater Core Replacement [Re: GO_Fish] #1158796
01/16/12 06:55 PM
01/16/12 06:55 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Mine leaks so back flushing may make me disconnect it all together...My dash is fine 277K now and not a single crack.....
Re: 2001 Ram 2500 Heater Core Replacement [Re: 68GTS383] #1158797
01/16/12 07:27 PM
01/16/12 07:27 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
It is not that hard. The dash is designed to pivot out. You loosen a bolt in each kick panel and the dash will "roll" forward towards you.
Remove the ABS, lower the steering column first of course. 5 bolts and a pesky screw on top fo the heater box and it is out.
I have a quad cab and I tied the das off to the latch for the quad cab door. I routed the strap through the grab handle for ease of direction of strap.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2001 Ram 2500 Heater Core Replacement [Re: 70Coronet500Vert] #1158798
01/16/12 07:28 PM
01/16/12 07:28 PM
St Charles MO
St Charles MO
heres the box I bought evap and heater core
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2001 Ram 2500 Heater Core Replacement [Re: 70Coronet500Vert] #1158799
01/16/12 07:29 PM
01/16/12 07:29 PM
St Charles MO
St Charles MO
last view - engine side
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2001 Ram 2500 Heater Core Replacement [Re: QuickBpBp] #1158800
01/16/12 08:09 PM
01/16/12 08:09 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
My '01 didn't have a single crack until last summer. By summer's end it had one large crack and another small. I covered it with carpet at that point, not sure what I have now.
Re: 2001 Ram 2500 Heater Core Replacement [Re: 70Coronet500Vert] #1158801
01/17/12 12:12 AM
01/17/12 12:12 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
seem the heatercore will come out without disconnecting the evap?
Re: 2001 Ram 2500 Heater Core Replacement [Re: BigTerry] #1158802
01/17/12 08:02 AM
01/17/12 08:02 AM
St Charles MO
St Charles MO
absolutely. BUT you have already discharged your ac and you have the box out. What is another $60 for the evap? The heater core is around $50, so for $110 or so, all is replaced.
Plus you can clean the box, check the foams, etc. I made sure I reconfigured the box correctly after I took it apart by using a hand held vacuum pump
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2001 Ram 2500 Heater Core Replacement [Re: 68GTS383] #1158803
01/17/12 08:59 AM
01/17/12 08:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check the hose on the heater first.Both should be hot when you run the motor.If not it could be plugged.Ive cleaned a bunch by as said flushing them.A lot easier than changing the core.Rocky
Chrysler Firepower
