72 Charger SE weather strip roof rail source. #1158399
01/16/12 02:09 AM
01/16/12 02:09 AM
LA & L.A.
MoparPosterChild Offline OP
LA & L.A.
Can someone clarify for me where I can get roof rail weather stripping for a 72 Charger SE? All the places say theirs won't fit an SE because of a fixed window. Mine has the plug, but the window isn't fixed. Will the ones everyone sells work or not? I need new ones.
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
Re: 72 Charger SE weather strip roof rail source. [Re: MoparPosterChild] #1158400
01/19/12 01:14 AM
01/19/12 01:14 AM
Chilly Northern, Minn.
71 Charger R/T Offline
If you are referring to the top window seal that goes from the front of the door jamb up and over the door window to the back of the rear side window, Yes, the '71 and '72 non-SE seals are the same as the '72 SE. The glass is also the same just hidden behind the "plug". Now the '73 SE on the other hand is not the same as it has the stationary "opera" window as stated therefor having a 90 degree corner in the seal down the back of the door glass.
Hope this helps.
