Re: 727 needle bearing numbers and information?
[Re: jamesc]
#1157978
01/15/12 05:10 PM
01/15/12 05:10 PM
Posts: 27,377 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
The Torrington bearing numbers for the rear support are B-2414 (7/8") or B-2416 (1") or B-2420 (1 1/4") depending on the length you intend to use. If you intend to put a lip seal at the front of the bearing bore the 14 or 16 are necessary, without a seal the 20 can be used. By adding an "O" to the part number you get the needed oil hole. The last time I tried to get the ones with the oil hole they were discontinued but that's been a couple of years ago.
[Re: jamesc]
#1157980
01/16/12 04:57 PM
01/16/12 04:57 PM
John_Kunkel
Rio Linda, CA
There's some debate as to whether or not the roller bearing bleeds off lube pressure to the gear train, by sealing both ends of the bearing full lube pressure is sent to the gears.
If a bearing without the oil hole is used the seals would be omitted.
[Re: jamesc]
#1157982
01/16/12 05:50 PM
01/16/12 05:50 PM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
Roller thrust bearings are the GM TH350 Pump stator bearing 1976-86, Delco P/N 9436851, OD=2.900", ID=2.110", thk=0.140". You can also buy these from www.bulkpart.com, P/N 44211C. These replace the factory thrust washers. You have to machine the faces of the planetaries and the front annulus gear. Total gear train endplay should be about 0.008" - 0.015". The annulus gear is very hard, ~60 Rc. The planet pin axles are hard and it is difficult to machine the soft aluminum along with a hard pin at the same time. May have to use a carbide cutter to grind the pins down enough to make a clean face cut on the aluminum. The rear support can be done as John suggested. You can also machine off the low/rev drum hub and install a roller bearing in the low/rev drum with a reducing bushing. Torrington B2410 bearing or SCE INA 2410. You install a Torrington bearing in the narrow rear support with it hanging out the back slightly. It will obstruct the oil feed hole from the rear cooler line slightly. You have to clearance the front of the park gear for clearance. John
