What clutch and flywheel do you recommend?
#1157586
01/15/12 01:03 AM
01/15/12 01:03 AM
Posts: 1,293 Tucson AZ,
MadMopars
Tucson AZ,
I'm getting ready to order a clutch and flywheel for my Dart and am trying to decide what to go with. What flywheel and clutch setup are you guys using and what kind of ET's and 60' are you getting with them? This will be mostly for track use with limited street use.
Re: What clutch and flywheel are you using?
[Re: Rich970]
#1157588
01/15/12 09:39 AM
01/15/12 09:39 AM
Posts: 904 cleveland Ohio
mloboda
cleveland Ohio
Go to www.umtrnorth.comIt is a website dedicated to stick shift drag racing. look under the "clutch tech" section of the forum on that website. You'll find all the answers to your questions there.
[Re: mloboda]
#1157589
01/15/12 11:38 AM
01/15/12 11:38 AM
Posts: 10,044 MN
JERICOGTX
MN
McLeod Soft Lok, 12# aluminum flywheel. 3430lb car, has gone 1.37 60'. Bought the clutch from McLeod but it has since been reworked by Tim Hyatt, and it's the best money spent since buying the clutch.
69 GTX
68 Road Runner
[Re: MadMopars]
#1157591
01/15/12 02:53 PM
01/15/12 02:53 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
McLeod/Hyatt soflok also w/best of 1.35 60' in the barracuda. Had a aluminum flywheel but kept warping the steel insert on the flywheel and on the pressure ring (aluminum pressure ring with steel facing riveted). I generally run 2 classes so lots of hot lapping and the steel facings would 'potato chip' so it was getting expensive to replace those. So went back to a steel flywheel with a steel pressure ring which saved money and the car was more reliable/predictable. The aluminum parts save weight but the difference is not that great. Also I figured I don't get paid to go faster by .01. I would get away from the OEM flywheel and get an SFI FW. You can get the steel fw lightened. W/r to size, some of that depends on the bellhousing. If you have a lakewood (which I think they don't make now that they bought quicktime) then you can use 143t fw and get a bigger clutch. If you are using a quicktime then you're stuck with the 130t and a 10" clutch. It works OK for me, but don't really like the quicktime except it is about 20lbs lighter than the lakewood.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: oldiron]
#1157592
01/15/12 10:23 PM
01/15/12 10:23 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Advanced Clutches. Talk to Rob Youngblood. Best clutch guy in the business.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: What clutch and flywheel do you recommend?
[Re: MadMopars]
#1157593
01/15/12 10:52 PM
01/15/12 10:52 PM
Posts: 22,721 Bitopia
jcc
Bitopia
How about the 9.5" multi plates with alum FW?
