Re: Handling tips for trucks
[Re: 70Cuda383]
#1157464
01/05/13 12:59 PM
01/05/13 12:59 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
How does stiffening the cab to frame mount points help the suspension work better? By reducing the tendency for the weight of the cab to shift in a hard turn?
I don't think any of the Dakota guys have done that, and yet lots of us are super happy with the hotchkis stuff and how it improves handling. I don't know if boxing the frame will gain anything, sure it'll be stiffer, but it'll be a lot heavier too.
There's a guy making some cross bracing for the Dakota frames which help to stiffen everything while only adding 30-ish lbs. Frame twist is greatly reduced!! Stock frames you can see the frame twisting when you hit bumps, as the bed looks like it "rattles" when you see it in the side mirror. Add the cross brace and that goes away. Then again Dakota frames are fully boxed from the front to just behind the cab anyway, and only the rear half under the bed is a "C" channel
Got a link or contact info for the Dak guy?
Rick
[Re: Rick_Ehrenberg]
#1157465
01/06/13 02:55 PM
01/06/13 02:55 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Rick
I'd PM it to you, but you don't accept PMs
here's a link to his cross members
http://stores.hi-potek.com/-strse-DAKOTA-X-dsh-BRACES/Categories.bok
His name is Richard, lives in Michigan, and makes all kinds of cool stuff for the Dakota crowd. driveshaft loops, transmission mount cross members, solid engine mounts for magnum engines, plus he has a wide selection of motor parts, suspension parts, etc.
If guys show enough interest, I'm sure he could start making parts for other trucks.
**Photobucket sucks**
