Page 2 of 18 1 2 3 4 17 18
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156179
01/14/12 02:30 PM
01/14/12 02:30 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
The purists will cringe. Its an original B5 blue with B5 blue interior A66 340 car. Didn't have the original engine & trans when I bought it so I am building it my way. Been thinking about doing all of the interior in the original B5 blue color even with the alum Kirkey racing seats. I think it would contrast good with all of the black tubing every where or black interior with the cage bars painted B5 blue.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156180
01/14/12 03:45 PM
01/14/12 03:45 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Looks Great!! Moly Tubing?
All Moly tubing. Very similar to how your old car was done.
Your A-Pillar & Dash bars look very familiar.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: STEFF] #1156181
01/14/12 03:55 PM
01/14/12 03:55 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Yes, Thank you very much for the pictures you sent to me quite some time ago. They have been very helpful in making some important decisions.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156182
01/14/12 04:28 PM
01/14/12 04:28 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
one thing you may want to look into while still in fabrication stage is the 25.3 spec. the couple extra bars will allow you to cert. to 6.0 instead of the 7.50 with the 25.5. you may never use it but is nice to have if you ever do upgrade down the line. also one mistake i made is checking for clearance on the dash bar (same as yours) the stock cluster will not fit
Kind of thought about 25.3 but with my budget it will never go 6's. Going to be using aftermarker gauges. Stock ones are to dang hard to see at night. ecspecially, at high speeds. Would like to do the "All Motor" &/or stock suspension classes, but I have enough NOS to nuke a small town for my 440 build & for future use (2) 106MM turbos for the alum HEMI build. Won't even need the 7.50 cert at first but at least it will be all done right.
A pair of 106mm turbos on a Hemi will put you well past 7.50et's unless you never use more than 5psi I agree with prochargedhemi, take the time to go for the 25.3 cert.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: STEFF] #1156183
01/14/12 09:15 PM
01/14/12 09:15 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
kinda funny really, we both copied parts of steffs old ride. good luck seems like your in the same boat as me not sure which direction you wanna go. got any questions let me know, i have a few ideas that would be super cool for "stock suspension" on a mopar
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156184
01/14/12 09:33 PM
01/14/12 09:33 PM
STEFF Offline
STEFF  Offline
Glad I could help out! If you could, please email me back copies of those pics. I had an external hard drive issue and lost all of the build pics I had of my Chally.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: STEFF] #1156185
01/15/12 10:49 AM
01/15/12 10:49 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Do you have any pics of all the floor bars installed? I'd like to see that if possible. Looks great!
Steve
Photobucket sucks
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 72chrgrally] #1156186
01/15/12 11:56 AM
01/15/12 11:56 AM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Build looks great...Keep us updated
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Gary Robbins] #1156187
01/15/12 01:31 PM
01/15/12 01:31 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
awesome
Mopar Performance
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Defbob] #1156188
01/15/12 01:52 PM
01/15/12 01:52 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Once I finally do get to the turbo build. I will probably just run of the one 106's & use the other one as a spare or a parts turbo if ever needed. I think it is too aero disadvantaged to ever go 6's easily. The front end is just a big scoop. Leaving it all steel. No solid front one piece lift off front end for me.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 72chrgrally] #1156189
01/15/12 01:57 PM
01/15/12 01:57 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Steve
I do have a few of the floor bars/frame connectors. Still have a few more underneath to do. Been focusing on the rear suspension/narrowing of the Dana to fit in the mini tubs. It will fit 315's D.R. or a 29.5 x 10.5W with no problems. I'll post some more. Later in the week. I only have them saved to my work computer.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: STEFF] #1156190
01/15/12 02:11 PM
01/15/12 02:11 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Will do Steff. I have 4 or 5 of those zip files you sent me saved at work. I will try to send them to you tomorrow.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156191
01/15/12 04:33 PM
01/15/12 04:33 PM
Chesterfield Twp. Mi.
John Burdine Offline
25.3 now, you wont want to go back and do it later. pretty sure 25.3 is good to 6.50 @ a max of 3600 lbs.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: John Burdine] #1156192
01/15/12 07:33 PM
01/15/12 07:33 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
25.5 should be more than enough to cover me for now. It will probably be years if at all that I get into the 6's. By then the rules/specs will probably change anyway. Just want to get something back out onto the track now that the kids are all getting older.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156193
01/16/12 08:31 AM
01/16/12 08:31 AM
STEFF Offline
STEFF  Offline
Thanx!!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: STEFF] #1156194
01/16/12 09:51 AM
01/16/12 09:51 AM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Steff,
Please PM me you e-mail address. The one I have (may be an old one) did not go thru. Thanks.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156195
01/16/12 11:20 AM
01/16/12 11:20 AM
STEFF Offline
STEFF  Offline
Steff,
Done!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: STEFF] #1156196
01/16/12 12:15 PM
01/16/12 12:15 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I sent you the 4 Zip folders as you sent them to me. Hopefully, they went thru O.K.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156197
01/16/12 12:19 PM
01/16/12 12:19 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Another
What do that bar that connects to the crossmember to the inside frame rail connects to or do it just dead head into the frame?It looks good.............
It goes thru the trans cross member part of the frame, then turns & goes thru the other part of the front sub frame & then up on an angle to the inner rocker panels with plates welded to the inner rocker panels. I think I have pictures of that too. I'll look.
here is a pic of the frame connector looping over to the rocker bar tieing into the rocker & the "A" piller bar coming down into it.
Going to be filling the two open hole with sheet metal.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156198
01/16/12 12:22 PM
01/16/12 12:22 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Steve
This is all I have for now until the other bars are finished.
