B1 Original engine requirments?
#1153042
01/08/12 08:01 PM
01/08/12 08:01 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
For the guys who's running these heads.. What do you feel minimal cubic inch should be on a fully ported B1 Original engine would need to be? What kind of RPM would a 499 want to shift at for best power/torque? I figure 7300 atleast.. Looks like the intake runner volume of my heads are a good bit smaller than my 440-1's (CNC by Modern) 360cc Indy Vs 315-320 cc B1. But the B1 heads flow 25-30 cfm more at this less runner volume. But does the B1 heads make more torque down low? IMO I think these heads (Indy 440-1) are on the lazy side on a 493 cid I had which had moderate compression (about 12:1).. So I guess Im wondering what the power curve would look like on this old engine using same cam except the B1 heads. I will say I felt the older engine really wanted 2 more points in compression. The Indy engine did run 114-115 mph in the 8th mile at 3400 lbs at best. 60 foot was always sluggish IMO in the mid 1.3's and figured the added compression would really help mid range torque and 60ft times.. I will also note the new engine with the b1 heads will have minimum of 14:1 compression... Just getting ready to machine this stuff and need a few decisions to make, like Compression ratio etc.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: B1 Original engine requirments?
[Re: Bob_Coomer]
#1153043
01/08/12 08:58 PM
01/08/12 08:58 PM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
the ports and valves are in different locations, between the -1's and the B1's. so I don't think you are doing a apples to apples comparison.
Joe
Without Data, you’re just another guy with an opinion.
[Re: Bob_Coomer]
#1153045
01/08/12 10:20 PM
01/08/12 10:20 PM
Posts: 16,934 NC
440Jim
NC
I am surprised your B1 heads have less runner volume than the 440-1, does that include the difference in the intake (low deck vs RB or adapter volume)?
I do think the laziness you saw could be due to the compression ratio. I saw the same thing in a friend's 499 CID with Indy SR heads.
Nobody thinks my Indy 440-1 setup is low on torque and it is only 511 CID. But does have 13.5 CR, 279/287 cam and slightly smaller runner volume than yours. Back to one of your questions, I think the B1 originals will work just fine at 500 CID and up; 13+ CR, 5500 stall, etc.
[Re: sr4440]
#1153047
01/09/12 02:08 AM
01/09/12 02:08 AM
Bob_Coomer
Rock Springs
Joe
exactly If they were the same, what would there be to compare? Im comparing the operating and power range of two diff cylinder heads, trying to base it off of runner size.
What level of power are you trying to obtain? What kind of car (weight)? Max effort or? single 4 or ? aftermarket block or ?
Its a bracket engine, what ever it ends up making is fine. but I want to optimize the performance best I can from what parts I havent already purchased. It is a single four B1 cast single 4 with a 8896 Dominator. Short block for now is a stock thick main 400 block. I have the rotating assembly already.. Its a Billet LA Enterpiise Kryptonite 4.15 stroke crank, BME aluminum rods, and Venolia Pistons. Heads have been fully ported, intake has some level of porting also. I have T&D paired rockers with 1.75 RR, and a Old UltraDyne Solid Roller with 275 deg@50 and works out to be .800 lift. Car is no light weight, but is in the 2600 lbs range... 6K converter (727) and 4.56 gears. Compression will be 14:1 or so. Its not to late to change some parts out.... If I can get by a few seasons, I will build me another Indy maxx short block. Right now I want to get the car out and lined out, Its never been raced or finished and needs a few more parts to finish that up. Quote:
Koffels claims 300 cc OOTB port size. I plan to cc the heads and chamber this week, to get a idea on how much to deck, and what I need to do to adjust compression wise. These have NOT been ported to death like I see lots of the B1 stuff. Id say the Toilet injection really helps with the throttle response down low... I ended up getting a setup and switching to alky, but not with the 493 short block. I think the old Dakota engine was a little lazy down low, I ended up switching cams, sending the converter off for another adjustment. It defiantly like leaving at a higher rpm. But the truck was deadly consistent, and always hooked well. It really came alive in 2nd and high gear. At one point I purchased a set of nice used Ross Dome pistons for the 493 which would have made the engine 14.5:1 compression, which I felt really would have woke the truck up. I felt the heads and cam and top end in general was a little big for a 493 with 12:1 compression. I ended up selling the short block and building a Indy maxx large bore engine and used the topend and valve train on that engine...
![](http://i93.photobucket.com/albums/l45/The_Dakota_Kid/IM003799.jpg)
[Re: Bob_Coomer]
#1153048
01/09/12 02:35 AM
01/09/12 02:35 AM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
My first B1 was a 451. We shifted it at 7400 and it eventually ran 9.30's in a 2400lb tube chassis Daytona, this was in the early 90's.
The next one was a 511" in the Valiant and went 9.0's at 150 weighing 3470 shifting it at 7100rpm. Frankly I did not do enough tweaking on that car to ever figure out where it wanted to be. I suspect it woudl have benefited form a bit more RPM but pure speculation.
The current B1 in the Cuda we shift at 8300 runnign it all out. It makes Peak HP at 7700. I did some shift cycle testing and found we were quickest at that RPM. Partly because of the way tight convertor and glide. I think with the cirrct set up 8100 woudl be a more realistic place for it. But I tell you it pulls like a freight train up at that RPM.
[Re: Bob_Coomer]
#1153049
01/09/12 03:01 AM
01/09/12 03:01 AM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
Joe
Its a bracket engine, what ever it ends up making is fine. but I want to optimize the performance best I can from what parts I havent already purchased. It is a single four B1 cast single 4 with a 8896 Dominator. Short block for now is a stock thick main 400 block. I have the rotating assembly already.. Its a Billet LA Enterpiise Kryptonite 4.15 stroke crank, BME aluminum rods, and Venolia Pistons. Heads have been fully ported, intake has some level of porting also. I have T&D paired rockers with 1.75 RR, and a Old UltraDyne Solid Roller with 275 [Email]deg@50[/Email] and works out to be .800 lift. Car is no light weight, but is in the 2600 lbs range... 6K converter (727) and 4.56 gears. Compression will be 14:1 or so. Its not to late to change some parts out.... If I can get by a few seasons, I will build me another Indy maxx short block. Right now I want to get the car out and lined out, Its never been raced or finished and needs a few more parts to finish that up. Quote:
B-1 needs more duration somewhere in the 305-315 range.
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: poppaj]
#1153050
01/09/12 11:08 AM
01/09/12 11:08 AM
Posts: 10,034 Frostbitefalls MN (Rocky&Bullw...
gregsdart
From the Fastest cars post 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide Single dominator 400 block 4.25 stroke
[Re: gregsdart]
#1153053
01/09/12 02:35 PM
01/09/12 02:35 PM
Bob_Coomer
Rock Springs
wow That car runs well, very well.. I guess that would be a good goal to shoot for, kinda like winning the lottery lol. Id like to talk to Ken if anyone has a email address etc.... I know he's been running the B1 stock block setup for years. If It will run in the mid t upper 8's I will be happy. Its been a while since I have run aluminum rods, so this engine needs a little more planning and thought than the last couple of race engines I have built. As far as the cam goes, its probably not optimized, fact is it was cheap, and its in the ball park for duration and lift I wanted. I have built two cars in the last 3 years (one from scratch), and never really been out racing, matter of fact is it has been 10+ years since I havent been able to get out and atleast make a single pass. So, Im kinda anxious
[Re: Brian Hafliger]
#1153056
01/09/12 05:06 PM
01/09/12 05:06 PM
Bob_Coomer
Rock Springs
This would be the way I would go with bore and stroke. Some Ultradyne cams don't like alot of Rocker ratio/or heavy valvetrain so just be carefull there. Run a min. of 7/16 pushrods. I'd run 14:1 compression min. I know you already have it, but a larger carb (1250) would be much better! If I were picking the cam it might look like 276-282@ .050 and around .825 lift at the valve. I'd go with Diamond pistons. Sounds like fun...love them B1's!! Brian
Hey Brian the cam stamped 311 R8 has .454 lobe lift and is 278@50 with the lobe lift and rocker ratio it works out to be .795 gross. Just wondering what you think of this cam and lobes. Im betting the higher rocker ratio will make the dur out a little higher, maybe 280@50. Install it at a 106 ICL or so, use 240 lbs seat and 650-700 lbs open. I have had great luck with the 1224 Pac spring which I will most defiantly use. Cam has about 197 deg@.200.... I do know Bullet grinds this lobe in Chevy's all the time according to Curt at Bullet Cams.
[Re: Bob_Coomer]
#1153057
01/09/12 06:17 PM
01/09/12 06:17 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Bob, I'd install the cam straight up...no advance! try it...only way you'll know if you like it.
Brian Hafliger
[Re: Diablo]
#1153061
01/10/12 02:24 AM
01/10/12 02:24 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Obviously the lighter the valve the better for valvetrain control, but with the spring pressures you'll be running, it ought to keep things under control. A friend of mine built a 540 (4.5 stroke, 4.38 bore) mega block, B1 headed street motor. About 11:1 CR and a solid flat tappet cam. It was making power like crazy until about 6800-7000 and the valves floated. Lucky he has dished, low compression pistons or it may have tagged a valve. We all told him to run a roller but he kept saying it was a street motor. Yep, a 540 inch, 395 cfm headed street motor that you have to look around when you drive because it sticks so far out the hood. ![](/ubbthreads/images/graemlins/eyes.gif)
