Re: Slow Mopars [Re: 340man4ever] #1153001
01/10/12 11:47 AM
01/10/12 11:47 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
They are W2's... Home Ported, with a set of Gold Crane rockers.
He races all the Chrysler series over here on the east Coast... He hardly misses a race....
He dyno'd the engine when it was first assemble. It did make 630hp, and the dyno has been known to be accurate.
Re: Slow Mopars [Re: slippery440] #1153002
01/10/12 01:30 PM
01/10/12 01:30 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Vic, I gotta tell you, my Junk 65 Barracuda, is Junkier than yours!!!!!!!!!!!!!
It's not as rough as it was when I got it; it doesn't have a Fred Flintstone floor pan any more, nor do the quarters have holes you can put your head thru. It's flat black, pained with a brush, I embrace it's crudeness!! It's over looked till it goes down the track and then people sit up and take notice.
A stock stroke 360, internal balance, KB 107's, Sir rods, Hughes ported E-brock heads, M1 single plane, Holley DP750, MP 557 cam, Hughes 1.6 rockers, 5000 stall PTC converter, John Cope race built 904, Cal-Tracks w/mono leaf springs, 8 3/4, choice of 4.88/4.56 gears, Hoosier 28x9 slicks, 3030 lbs with me in it.
Best 1/4 mile time is 11.10@ 120 mph, best 1/8 mile time is 6.94, best 60ft is 1.455.
10 years building and less than ten grand invested.
Re: Slow Mopars [Re: JBurch] #1153003
01/10/12 08:55 PM
01/10/12 08:55 PM
Central New York
slippery440 Offline OP
Crybaby440
Crybaby440
Central New York
Jim anytime you say that it not true. You have one of the most look at cars down there. Anyone can own a Dart but how many 65 Cudas do we see? That car just runs great.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Slow Mopars [Re: slippery440] #1153004
01/10/12 09:56 PM
01/10/12 09:56 PM
Columbus, Ohio
JLC Offline
JLC  Offline
Columbus, Ohio
64 Polara 500, 440.030, cam .572 .579, 440 source heads, Mopar crossram intake, 4.30 gears,ss springs, 12.00 @ 114.52. all steel weight ?.
Re: Slow Mopars [Re: JLC] #1153005
01/11/12 02:15 AM
01/11/12 02:15 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Keep em coming.......
But in the theme of the original poster:
Budget minded and stock stroke combos!
Curator at Adams County Speed Shop
Re: Slow Mopars [Re: slippery440] #1153006
01/11/12 06:01 PM
01/11/12 06:01 PM
South Carolina, United States
carolinacuda Offline
I gots a 74 cuda and im in the same boat as alot of people although i do have a few good parts on my engine, it's still pretty basic combo. I ran out of money so i have just kept it the way it is for now. It has stock susp with 8 3/4 and 3.91 gears. A stock block/stroke 440 with trw pistons. A Hughes solid 575lift cam with Eddy Victor INT. topped by a 850 demon. Heads are Indy Ez'z stock port kind. No porting on the int nor heads. 275/60 M/T street radials. Trans is 727 with a cheap TCI 3500 stall. I normally run 11.40's but my best so far is 11.37 at 119mph. Want a better stall and do some porting. Prob got 11.10's in it. My goal is to get into 10's one day when i get money.
Re: Slow Mopars [Re: 340man4ever] #1153007
01/11/12 11:03 PM
01/11/12 11:03 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
My car:
1974 Dodge Dart Swinger 2dr 3300lbs race ready on line.
Flat top piston 440, zero decked, (11.25:1 compression) with ported 915 heads- Flow 268/207 peak. I run mopar 590 solid cam, M1 single plane intake, McCandless headers, 850HP carb./ 9.5 Dynamic converter (high gear flashes 5100)
Mopar Superstock leaf springs, clamped in rear with pinion angle set at 6.5 degrees nose down. Mopar long drag shocks in rear, 3 way Competition Engineerings in front. 6cyl Torsion bars / 30x9 Hoosier slicks. 4.30 rear gear
Bests for 2011 footbraking:
10.77 @ 122.8mph 1/4 mile Cedar Falls Raceway Sept 23
Incrementals:
1.47 60ft 6.80 1/8th @ 99.79 mph
Looking forward to this year!
hey our cars are pretty close in engine and performance. have any pics of your dart. But here is the lowdown on my junk.
all steel 1973 dodge dart. guessing 3500 pounds race ready
1973 440 0.030 over with wisco flat tops.pistons 0.006 down.
stock stroke forged crank
eagle rods
felpro 8519 head gaskets
bowl ported Indy EZ heads
crane gold 1.6 roller rockers
manton push rods
comp cams solid roller 0.264 @ 0.050 and 634 lift with 1.6 rockers
mopar m1 tunnel-ram 2 750 cfm carter comp carbs
tti 2x3-1/2 headers
727 with dynamic 9.5 converter stall around 4500
8-3/4 4.30 gears
15x8 wheels with M/T et street drag radials
this engine should be right at or real close to 11.1.1 compression. i race it with 93 pump gas.so far my best has been a 10.68 at 125 in the 1/4 and 6.88 at 100.8 1/8 mile. my car is a dog off the line. my best 60 foot was only a 1.56. also i was only running 4.10 gears when i ran the 10.68 but blew up my 8-3/4 on the fifth pass that weekend. I have sense then put a set of 4.30 gears and was only running 11.00 flat in the 1/4.that night it was 85 degrees at 11.00 pm.I only got to go to the track one time last year.I have around 7000 in the engine.I would like to make it go faster but just don't have the money right now.been thinking about just selling the car and getting out of racing.OK enough of my You guys have some nice and fast cars on here. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Slow Mopars [Re: challengermike] #1153008
01/11/12 11:15 PM
01/11/12 11:15 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Here's the details of mine. 360 block .030 over with kb 107's, cast crank, stock rods. Unported edelbrock rpms, 525 comp solid cam, rpm air gap intake. 750 hp holley on e-85. Has run a best of 7.13@94 in the 1/8.
Super stock springs in stock location, stock wheel tubs, 83/4 with 4.30 gears and spool.
Re: Slow Mopars [Re: moparguy7074] #1153009
01/12/12 08:33 AM
01/12/12 08:33 AM
Central New York
Crybaby440
Crybaby440
Central New York
You guys are proveing to me that we low budjit guys can and do have preaty fast cars.I have read on here and other mopar sites guys with "STROKER MOTORS" that are not as fast or just a bit faster and have a ton of money into the motor. Good job guys!!!
Re: Slow Mopars [Re: slippery440] #1153010
01/12/12 12:05 PM
01/12/12 12:05 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
Mines a 79 360.030 over. Kb 10.5 kb piston, eagle rod stock crank, .525 hy comp cam. 8 1/4 rear with 4.10's with 28-10.5 et streets. Tagged tittled and insured.. 12.50's at 106.
My buddies car is a Aspen and they are not light ether. 12.50S Is a nice ET.
I know its 3700lbs all the crash bars are still on it. me and the car need to go on a diet.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Slow Mopars [Re: slippery440] #1153011
01/12/12 12:36 PM
01/12/12 12:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
With all the fastes this or that post and who has the fastes this or that. I want to see stock blocks / stock stroke crankshaft / no power adders at all. This means carburator only.
My 69 Dart with a 340 ran 7.24 @ 94 mph with a 1.54 60'. It weighed 3240# with me in it.
.030 over, Ross flat tops, ported Edlebrocks, 11.2-1 compression, Weiand X-Cellerator, Hughes hydraulic cam and Hughes rockers, 727, 8 3/4 with 4.30s. Full interior, heater, wipers and radio that doesn't work. It ran on pump 93 and could be driven anywhere and not run hot.
The 408 picked up a bit .
Re: Slow Mopars [Re: justinp61] #1153012
01/12/12 07:19 PM
01/12/12 07:19 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have a budget i dont like to go over, even though i have the spare cash, so i look for good deals on used and new parts and try and glean as much info off the net and other people's experiences as i can.
The advice i've had off here as been invaluable in my pursuit of et.
My combo
Dart GTS 3200#, 440 RB, MCH ported RPM'S,12.5.1 JE domes, .590 cam, isky rockers, victor intake, 950 holley, 727 with 9" Ultimate converter, dana 60 4.56 gears, SS springs, 31x10.5 hoosiers.
Bob, what does that Dart weigh ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
