Re: Need B-1 orginal pistons [Re: MR_P_BODY] #1152108
01/12/12 07:09 AM
01/12/12 07:09 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
What diameter pistons... I have a new set of b-1 m/c
pistons for a 4.440 bore that will be for sale
also what compression
4.380
Re: Need B-1 orginal pistons [Re: Jeepmon] #1152109
01/12/12 02:00 PM
01/12/12 02:00 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
The good coatings are only good for about .0005" on each side.
http://www.swaintech.com/store.asp?pid=10964
PC-9™ is commonly used to salvage a motor that has excessive piston to wall clearance. Vintage motors and other applications with hard to find pistons can
have up to .004” of PC-9™ added to the diameter of a piston to tighten piston to
wall clearance.
Jeepmon said:
"When I looked into having my pistons coated.. I think the coating is good for .002 per side which will only be .004 total... and there's nothing to prevent the coating from scratching off.. "
__________
Sounds fine for a restoration, but do you really want to add that much thickness in a performance application? Doesn't sound like you're that convinced that it's the way to go. When I said "Good coatings" I intended it to mean a high performance app. Maybe should have made that more clear.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Need B-1 orginal pistons [Re: 23T Hemmee] #1152110
01/12/12 02:14 PM
01/12/12 02:14 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
You're probably right...!! I'm the first one to admit I dont know enough about building motors... or race motors to state any facts.. I was just passing along information I found elsewhere..
