Re: Why so much hatred for the KYBs?
[Re: DartGTX]
#1152022
01/09/12 06:51 PM
01/09/12 06:51 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I have always had great success with KYB Gas-A-Just. They really tightened up the ride of my 70's and 80's cars. I tried the GR2 strut on a 85 Ford t-turd and hated it....... much too soft.
If you want a performance shock to control roll and help handling they cant be beat for the price.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: radar]
#1152027
01/10/12 03:48 PM
01/10/12 03:48 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I, too, have used the KYBs for many years and recently found out that they were 'junk'. I've used them only on C-bodies, though, so that might be a reason they were not objectionable. The last set went on a 68 Fury with 1.12 T-bars and a 1 1/8" swaybar. I do feel a lot more of the road than before, but the bars surely contribute to that also (never did bars before this car). Haven't felt it skip around due to bumps, but I try to limit C-tossing to familiar smooth roadway (this driver has found his limitations too many times in teh past ![](/ubbthreads/images/graemlins/laugh2.gif) ).
[Re: Fury Fan]
#1152028
01/10/12 05:28 PM
01/10/12 05:28 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I had KYB gas-adjusts on the front of my Road Runner for a short while. They were too harsh for me, I could feel every bump in the road and the whole car shook if I hit a pothole. I changed them for QA1 single adjustables and the difference was like night and day.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Mick70RR]
#1152029
01/10/12 10:46 PM
01/10/12 10:46 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I found the KYB shocks a great improvement. I had the same set on an F body that had a police suspension. I had them on that car for nearly 30 years. That car handled extremely well and had a good ride.
I think most of the haters have poly bushings and other poly components that make the ride harsh.
I bought my rear KYB shocks at the mopar nats for $5 almost new, bought the fronts for $27 each. I'm going to try them on my stock rubber bushing Challenger and see how it goes. I replaced a set of $200 drag shocks and know they will be better than that. I just need to get my car out of paint prison.
Carquest shocks are made by KYB, are black in color, and seem to be reasonably priced.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#1152032
01/11/12 12:55 PM
01/11/12 12:55 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Understanding the difference between progressive, digressive, and linear valving combined with road conditions and the ever present "driver capability" variable goes a long way in understanding why some shocks feel overly soft while others feel too stiff. Suffice it to say there are so many variables at play that, like a broken clock is correct twice a day, so too can even a piece of junk like a KYB can work well on some combinations, in some environments, with some drivers.
In any case, to understand appplication of shock dynamics and capability is a big reason why so many Cup cars are so fast while others are also ran. Two decades ago there was no such things as a shock engineer and nobody bothered to dyno their shocks. These days, if you want to be a front runner, these are important things to have if you ever want to win. The understanding and capability of a shock is of paramount importance to the overall suspension operation.
Lets put it in these terms; shock absorbers are to a suspension what a camshaft is to an engine. Much like a cam will determine an engines useful range, power levels, ranges of power, and curve of power, so too will a shock operation within a suspension system to determine operating characteristics, manners, and feel. Matching shocks to suspensions achieves results similar to matching cams to engines. Sure any old thing thrown in there will work, but when you seek to achieve optimal results, the cheapest shocks with the most pressure are not going to be any better than using the cam with biggest lift and longest duration.
[Re: racealittle]
#1152033
01/11/12 01:01 PM
01/11/12 01:01 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
I am pretty sure the Carquest shocks are the in-house brand of the KYB GR2 shock, not the "gas-a-just". GR2's are much softer.
[Re: jcc]
#1152035
01/14/12 08:13 AM
01/14/12 08:13 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
So to run big tires like 295-50s or 275-60s what do you need on the rear to avoid rubbing issues... My car came with these but they have to go so I am sitting here with 4 brand new KYB shocks and now afraid to install them as I have heard the HARSH/DRIVES LIKE A TRUCK crap for a while now... Im not an air shock guy either.. ![](/ubbthreads/images/graemlins/laugh2.gif) That exhaust is loong gone too.. ![](/ubbthreads/images/graemlins/eyes.gif)
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: Kern Dog]
#1152038
01/15/12 04:44 PM
01/15/12 04:44 PM
Posts: 22,728 Bitopia
jcc
Bitopia
This really should be in "corners"?
