Re: Which roller rockers with RPM heads [Re: dragram440] #1150777
01/05/12 06:40 PM
01/05/12 06:40 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
+1 on the Harland Sharps, other rockers are reserved for little flat street cams
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: Which roller rockers with RPM heads [Re: 00snake530] #1150778
01/05/12 07:19 PM
01/05/12 07:19 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
Not RPM heads but Harland Sharps in our 360 SuperStock engine program..no corners cut!
Re: Which roller rockers with RPM heads [Re: CompWedgeEngines] #1150779
01/05/12 08:54 PM
01/05/12 08:54 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Thanks TEd.
Be aware, standard h
Harland Sharps WILL work on the RPM heads, but the fitment is not as exact as I would like to see. I offer sets made to better align the roller tips for RPM heads. Let me know if I can help.
I heard that recently aswell. And you can get harland sharps that work specifically for the rpm heads
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Which roller rockers with RPM heads [Re: Kam*Kuda] #1150780
01/05/12 08:57 PM
01/05/12 08:57 PM
tboomer Offline
tboomer  Offline
Trust me...Todd is a good guy and will tell what works and what won't. He can fix ya up!!
Re: Which roller rockers with RPM heads [Re: Kam*Kuda] #1150781
01/05/12 09:33 PM
01/05/12 09:33 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The HS are a little long on the RPMs, the rocker tip will run outside of center on the valve tip. IMO, it is no big deal.
I'm using the Comps on my roller cam street car with no problems. I think any of those choices are fine if the new Cranes are the same quality as the old Crane Golds.
Re: Which roller rockers with RPM heads [Re: CompWedgeEngines] #1150782
01/05/12 10:49 PM
01/05/12 10:49 PM
Central NC
gch Offline
gch  Offline
Central NC
Thanks TEd.
Does this hold true for the 440 source heads?
Sorry for thread hijack btw.
Re: Which roller rockers with RPM heads [Re: gch] #1150783
01/06/12 03:49 AM
01/06/12 03:49 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
They will work fine on the stealth head. I had them on mine.
Mike
1969 Dodge Dart Swinger
Re: Which roller rockers with RPM heads [Re: dragram440] #1150784
01/06/12 12:35 PM
01/06/12 12:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Anyone ever run these?
http://www.ebay.com/itm/Mopar-361-440-19...=item19cc17c610
I call those Shanghai Sharps!
And, no, I wouldn't use them on anything I'd own.
Re: Which roller rockers with RPM heads [Re: BradH] #1150785
01/06/12 01:14 PM
01/06/12 01:14 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Note the elongated axle holes on this less than a month old set!
RIP Monte Smith
Re: Which roller rockers with RPM heads [Re: CompWedgeEngines] #1150786
01/06/12 01:19 PM
01/06/12 01:19 PM
Syracuse,NY
Syracuse,NY
as well as the failing upper bridge portion of the rocker body and axle....not good, very poor copies.
The Hughes stuff does seemed priced well and a good value. I think the H/S could hold up a bit better under a little higher loads,and I have some long term experince with them in many brakcet and Super Gas type cars, but not sure what your future plans are, so thats got to be your call there.
The last few set of Cranes I ordered were still the " old" style, and they had not yet started shipping their new pieces, so until that happens, I cant say how godd they actually will be.Roller cams in my opinion need a little better rocker for long term service. Small roller snad solids, the Cranes did work great on.
RIP Monte Smith
Re: Which roller rockers with RPM heads [Re: CompWedgeEngines] #1150787
01/06/12 01:43 PM
01/06/12 01:43 PM
BradH Offline
BradH  Offline
Todd - Good info!!! IMO, people need to see & understand how these low-budget copies are INFERIOR to the originals in some significant areas. Rocker arms are really not a place where you can "cheap out" with a true performance engine.
Re: Which roller rockers with RPM heads [Re: BSB67] #1150788
01/06/12 01:50 PM
01/06/12 01:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not perfect but w/lash caps, 7500 rpm shifts and 7+ years later they`re fine and my guides were perfect..........
Re: Which roller rockers with RPM heads [Re: 383man] #1150789
01/06/12 03:02 PM
01/06/12 03:02 PM
BradH Offline
BradH  Offline
I like the Hughes roller rockers I use on my 493 with the EZ heads. They have been working fine and holding up good. Ron
I ran them w/ my Stage VIs and a solid flat-tappet cam w/ good results. I'm hoping they're up to running with 200#s more open spring load w/ the new roller cam.
