Re: restoring LCA's
[Re: burdar]
#1150666
01/05/12 01:19 AM
01/05/12 01:19 AM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
This might be of some help.... https://board.moparts.org/ubbthreads/show...&PHPSESSID=You could wire wheel them if you want a nicer finish. Good luck and post some photos once you get done.
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: restoring LCA's
[Re: burdar]
#1150668
01/05/12 10:38 AM
01/05/12 10:38 AM
Posts: 6,519 Buffalo, NY U.S.A.
MrNormsTA
Buffalo, NY U.S.A.
I used Krylon battery protectant in a shaker can. Looks pretty close to cosmoline, dries hard, and was good enough for my non OE perfect resto. Rick.
Re: restoring LCA's
[Re: burdar]
#1150670
01/05/12 12:54 PM
01/05/12 12:54 PM
Cuda Cody
Vancouver, WA
There's several way to do it, just how perfect do you want them? I love what David does with his level of restorations, but my experience with RPM hasn't been that great. I thought I might have gotten a bad batch, but when I called they said that wasn't the case.
Do you plan on driving your car or just a show car for OE judging? Anyway, here's a few I did testing colors and techniques.
[image]http://www.cuda-challenger.com/cc/index.php?action=dlattach;topic=81034.0;attach=146718;image[/image]
[image]http://www.cuda-challenger.com/cc/index.php?action=dlattach;topic=81034.0;attach=146719;image[/image]
Re: restoring LCA's
[Re: burdar]
#1150672
01/05/12 01:43 PM
01/05/12 01:43 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
Darren, Could you post some pics of the suspension parts that you treated with RPM? Also, how were the parts prepared before the RPM, bead blast, sand blast, acid wash, etc? I'm looking to see if they are different shades/colors to each part as they came in different shades/colors from the factory. TIA Ray
Re: restoring LCA's
[Re: burdar]
#1150673
01/05/12 02:53 PM
01/05/12 02:53 PM
Cuda Cody
Vancouver, WA
Hi Darren, Sorry about the links, they were just photos. One photo is shown in the post above and the other is just a close up. Please do not take my experience with RPM for anything other then what it is. Just my experience. I'm glad you've had good luck with it. I've heard soooo many great things about it and seen many others on here with nothing but glowing reviews of the product. That coupled with the work that Dave does led me to believe I had a bad batch and that's why I called. Based on what others have done with it and seeing what Dave does I would still recommend others that are doing OE Gold restorations try the product. For me, I went a different route. Since I will drive my cars in good weather, but still wanted a stock look I chose to blend 4 colors with air brush to achieve a similar look to cosmoline but with longer durability. Based on the other work I've seen you do, I'm sure whatever product you choose it will look fantastic. I look forward to seeing your car once it's all done. It should be one of the nicest! Have a great day. Quote:
None of your links work.
I've had great success with RPM. My spindles, calipers, tie rods, adjuster, center link, strut rods and many other componants are all bare metal treated with RPM.
The car will get driven but not in bad weather. RPM's abrasive tests have shown it to hold up well to road debris.
Re: restoring LCA's
[Re: Troy]
#1150676
01/05/12 03:25 PM
01/05/12 03:25 PM
rayztoy
Richmond, VA
Darren, Maybe this pic will help... NOS, courtesy of a board member here, but can't remember who...
Ray
.....but I dont remember where I got it from.
CRS Syndrome (can't remember sh_t)... very contagious...
Re: restoring LCA's
[Re: NV69B7RR]
#1150678
01/05/12 11:53 PM
01/05/12 11:53 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Here are a few pictures. This car was very rusty and a lot of the suspension parts do have some pitting. This is a reman caliper I bought many years ago. It was pulled from the box, disassembled and RPMed. The hose ends were also RPMed. Here is one of the spindles. It was sand blasted. I wanted to try and darken it a little so it wouldn't have that blasted color. Once it was RPMed, it did get too dark but I still like the look of it. All the parts were RPMed seperately, then assembled. The lower ball joint is the color it came...I didn't try to darken it at all. Here are the tie rod ends, center link and strut rods. The tie rods are new, the other componants are original to the car. These parts(except the new tie rods) were acid dipped to remove the rust. I did lightly wire wheel and steel wool the tie rod sleeves and clamps. One side of the car had the 70-72 style clamp nuts with the nylon pellits. The other side had the 73-74 style lock nuts.
Re: restoring LCA's
[Re: NV69B7RR]
#1150681
01/06/12 03:24 PM
01/06/12 03:24 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
If you use the Krylon battery spray, do it before RPM...DAMHIK..
Isn't battery spray basically a paint ?? Is Rpm made to be put on painted parts ?
Why would you put RPM on a part you were going to paint ?
Re: restoring LCA's
[Re: burdar]
#1150682
01/06/12 03:59 PM
01/06/12 03:59 PM
Posts: 502 St Louis, Missouri
Runnin74
St Louis, Missouri
Burdar, Are the nuts and bolts on that spindle assembly supposed to be black phosphate?
