440 Compression Ratio Advice
#1150562
01/04/12 10:15 PM
01/04/12 10:15 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I am building a stockish 440. The .030 over flat top pistons are .085 in the hole. The cam I'm using calls for minimum 9.5:1 compression. I'm on a budget and having a difficult time finding affordable heads to get me there. I was going to order the reman Aerohead 915s with 78cc chambers which would get me around 9.6:1 with .020 steel shim gaskets. Perfect, but since I figured my budget, the price has gone up on them and with shipping, they will be almost $900 for the set. Too much in my opinion for stock cast iron heads. My next thought was the 440 Source Stealths for about $180 more. A no-brainer right? Except the chambers on those are 80cc(+-) and I have to use the .040 composite head gaskets. That will get me 9.24:1 compression. Not far off, but under the minimum. And I really don't want to go through the added expense of tearing them apart and having them cut. Now for the question...will this be a significant/noticeable difference? Opinions? Thanks!! ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: 440 Compression Ratio Advice
[Re: 05dakota]
#1150566
01/04/12 10:46 PM
01/04/12 10:46 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
different pistons?
If you can, I would go for zero deck height and use a .040" gasket. This will give you good fuel mixing. With an aluminum head (something like a small chamber Edelbrock) and zero deck height you can run around 10.0 comp and not run into detonation problems on pump gas.
[Re: BSB67]
#1150569
01/05/12 01:16 AM
01/05/12 01:16 AM
bobs66440
This is the classic delimma of the low-buck short block. It appears that you have correctly figured it out, you have no good low cost choice. It will probably cost $2000 to make it right. Everything else will be a compromise. If you have the money for the Stealths, that is probably your most practical compromise. Some people run a shim gasket with them successfully.
How do you think it will run with the 9.24:1 with that cam? I asked at 440 Source and he said definitely not to use the steel shim gaskets. Also that the difference in compression wouldn't be noticeable and would be ok to run as is...but I would think they advertise a minimum for a reason??
Cam Specs: Summit SUM-6401 cam. Which states min. 9.5:1 compression. int .465 exh .488 adv dur. .282 int/.292exh int. dur @ .050 .224 exh. dur @ .050 .234
[Re: bobs66440]
#1150570
01/05/12 02:02 AM
01/05/12 02:02 AM
DaytonaTurbo
Manitoba, Canada
Many on here have run aluminum heads with the steel shim gasket. They spray the gasket on both sides with permatex copper coat and you're good to go.
FWIW, the summit cam you have listed there is not that aggressive of a cam. You can easily run that cam with 9.2 compression. I ran more cam in a smogger 440 with an actual calculated 8:1 compression and it did okay. Also, the .4 of compression difference between the two sets of heads you are thinking about, will not be noticeable on your combo. My brother has a 66 charger with a 440, stock heads, same 6401 cam and probably about the same compression as you're shooting for and it runs well.
Another option is to see if someone is selling a used set of closed chambered iron heads in the for sale section here on moparts. Sometimes there are good deals to be had, however the stealth heads will flow better OOTB than those stockers.
[Re: DaytonaTurbo]
#1150571
01/05/12 03:10 AM
01/05/12 03:10 AM
Posts: 5,170 CT
GTX MATT
CT
Don't worry about it, just put the cam in and run it. You won't notice the difference.
[Re: DaytonaTurbo]
#1150574
01/05/12 08:27 AM
01/05/12 08:27 AM
torkrules
I'm neurotic
I'm neurotic
You can always use Cometics. They make a .027 thick gasket if needed.
[Re: bobs66440]
#1150575
01/05/12 09:08 AM
01/05/12 09:08 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I ran 12.90's @ 104 with the same cam in a MAYBE 9:1(stock speed pro replacements) 440, RPM intake Holley 750DP, non-ported 906 heads, 1 3/4 headers, same 175k convert, and 3.91 all packed into a nice light (3850) 67 coronet. I wouldn't worry too much about it. If you go w/ the stealths you always have room to grow.
[Re: torkrules]
#1150576
01/05/12 09:21 AM
01/05/12 09:21 AM
bobs66440
Ok guys, Thanks for the replies! Sounds like the Stealths are the way to go. I appreciate it! ![](/ubbthreads/images/graemlins/thumbs.gif) Quote:
I was on their site and all I see is .040 gaskets. Are the .027 ones custom?
[Re: bobs66440]
#1150577
01/05/12 11:44 AM
01/05/12 11:44 AM
Posts: 75,134 A Banana Republic near you.
JohnRR
The cometics are very expensive, run the .040 gasket that the source recommends.
Also plan on having the heads disassembled and the valve job checked and also check the retainers and locks. Have the chambers CC'sd also, they may be a little bigger than advertised.
I ran that cam ain an advertised 9.2 compression 383that had 130k miles on it , probably more like 8.0 , and it ran well.
[Re: Mr.Yuck]
#1150581
01/05/12 02:38 PM
01/05/12 02:38 PM
bobs66440
I have been watching the ads and there's really not too much...that's affordable anyway. I have a set of 906 heads that need to be completely gone through but they are, what, like 85-90cc or so? That will put my compression way down in the basement. Then I would have to go with another cam or pistons. The Aeroheads were really the perfect solution because they are 78cc, but the price with shipping ended up in the same price range as aluminum heads. I priced out rebuilding my heads locally and it's a little cheaper, but I still have the compression issue. The engine in the car now is a stock (I believe) '66 440 from a Imperial or similar. I'm not sure what heads are on that but they are in worse condition than my 906s...I suppose I could pull the valve cover and at least see what they are....and keep looking in the ads. BTW Mr. Yuck, I saw your car in Car Craft (I think it was anyway). Very cool! ![](/ubbthreads/images/graemlins/thumbs.gif)
