Re: Going Racing... Finally almost 4 years ago.........
[Re: Bigcube]
#1147918
01/01/12 11:32 PM
01/01/12 11:32 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Nice car.
Refresh my memory, is this the car that used to be raced by your father and you re-did it or am I thinking of someone else here?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Sledge_57]
#1147919
01/01/12 11:42 PM
01/01/12 11:42 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Looks amazing I am almost 4 years into my build and hope to be on the track in 2012. You car is a beauty!
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: smokinwoody]
#1147923
01/02/12 03:44 AM
01/02/12 03:44 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
most excellent job..how did the car do...
x2... The world wants to know.. and we want to know now dammit!!
[Re: Jeepmon]
#1147924
01/02/12 04:37 AM
01/02/12 04:37 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Not great news, but not on a wrecker..
Electrical issues.. That's why we test..
Car was down about 4 mph from last time out in better air..
Changed jets.. No change.. in ET or MPH..
Made a third run and lost oil pressure..
Decided to call it a day..
Did a compression test.. Found something weird..
#1-- 195 #3-- 198 #5-- 198 #7-- 200
#2-- 160 #4-- 180 #6-- 185 #8-- 181.... Beats Me.. Passenger bank is screwy.. No blow by, smoke or water..
So that's why we test..
Going to cut open the filter, and do a leak down..
Why do I do this again?
Car was a hit though.. saw a couple of members there..
Proof that I was there..
http://arizonaautoscene.smugmug.com/Cars...4877784_fZDff74
Chris..
[Re: B1Johnny]
#1147931
01/04/12 07:04 AM
01/04/12 07:04 AM
Chris'sBarracuda
Arizona
Okay.. Leaked the motor down.. All's well there. #2 cylinder intake valve lash was set wrong.. Reset and it came right back up to the other cylinders. Cut open the oil filter and it was clean.. Going to pull the pan and check bearings.. Better safe.. Drained 12qts of oil out of a 10qt pan and filter.. Couldn't possibly have sucked the pan dry.. Question Could losing oil pressure at top end be attributed to the bypass valve in oil pump cover?? Pressure came up immediately after lifting at top end.. Chris..
[Re: Chris'sBarracuda]
#1147932
01/04/12 01:06 PM
01/04/12 01:06 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Maybe cavitating the oil pump? What was the stripe RPM?
In my opinion that Mildon pan, at least I think you have the Milodon one, is not the best at controlling windage, or keeping the pickup covered especially in the shutdown. I personally would not rule out that as a possiblity.
Have you had a chance to check the valvesprings yet??
[Re: Al_Alguire]
#1147936
01/04/12 09:29 PM
01/04/12 09:29 PM
Chris'sBarracuda
Arizona
Have you had a chance to check the valve springs yet??
RPM about 7300..
Oil Pan is Milodon 31160 http://www.summitracing.com/parts/MIL-31160/
Haven't checked the springs.. Don't have a tool to get them off while on the motor..
I need the one that Koffel sells..
Chris..
